Unread 09-11-2007, 12:51 PM   #1
dinan540
dinan540's Avatar
Bad Wheel bearing?
What does a bad wheel bearing sound like? At low speeds, 10-20 mph I hear a noise coming from the left front wheel. It sounds like a bent rim (if that makes sense). I know the wheel isn't bent so I thought a bad wheel bearing. How would I diagnose it?
Thanks for the help.
Paul
540i with some mods
Unread 09-11-2007, 12:56 PM   #2
RSF5
RSF5's Avatar
Rate My Car: 278 / 340
Your Ride: NOOTHHHIIIINNG
Are you getting any shaking or vibrations at low speeds? What exactly is the sound?
Unread 09-11-2007, 01:04 PM   #3
dinan540
dinan540's Avatar
No shaking or vibrations. I heard the noise at low speeds while I was posting flyers for our lost dog. The best way I can describe it is if you had a flat tire and can hear the tire running asymmetrically. I hope that makes sense. I checked the tire, it isn't flat or low pressure and the wheel isn't bent. The noise is somewhat high pitched, maybe if you placed metal on the rotor and drove the car, at low speeds, less than 5 mph, it is barely audible, but at 20 mph it is somewhat high pitched and irritating.
540i with some mods
Unread 09-11-2007, 05:30 PM   #4
is it kind of like a roar? either way, i believe a bad wheel bearing would give you the noise all across the board in terms of speed, definitely not just at low speed
Unread 09-11-2007, 06:54 PM   #5
Bad bearings will be a low rumbling sound, particularly at lower speeds because at higher speeds, the bearings aren't weighted down by the car as much due to the forward momentum of the car. If they're really bad, you'll also get a high pitched grindy/squealy sound. You'll also feel and hear a bad bearing when cornering hard. Pop the wheel off and grab the rotor, you might see some movement in relation to the steering knuckle- then you'll know for sure. E39's wheel bearings tend to not last as long as other BMWs, so you may be due. The good news is that they're not too hard to replace on the E39, and no special tools required
Unread 09-11-2007, 08:46 PM   #6
D-sky makes some good points see if you get more noise when applying force to the wheel, ie turning, I would believe that you would hear it at most speeds, The last couple I have had seemed to get louder as I went faster and definitely noticeable when turning to put weight on a tire.
Unread 09-12-2007, 09:41 AM   #7
dinan540
dinan540's Avatar
Thanks for the advice, I will try to load it in a corner. Will it matter how fast in the corner that I am driving? Are we talking about a 45 degree or 90 degree corner?
thanks for the help. I will take the wheel off and check tomorrow. Busy with Temple activities today.
540i with some mods
Unread 09-12-2007, 09:58 AM   #8
With city speeds (25-30mph) you should hear it, particularly when coasting around a turn. engine noise at higher speeds may drown it out. The sharper the turn the more load you put on the corner. But it's quite subtle . . if you're hearing it at higher speeds like the others are saying, then the bearing is pretty badly shot already, and you should have noticed it much sooner around the slower speeds.
DIY: E30 Front Wheel Bearing Replacement mullethunter3 BMW OEM Parts Department DIY's & FAQ's 14 12-20-2014 07:22 AM
E39 Rear Wheel Bearing torque settings j4yp E12, E28, E34, E39, E60 2 09-13-2007 11:51 PM
E34 540i6 bad tranny output shaft bearing.... V-tecKILLAH E12, E28, E34, E39, E60 9 05-24-2006 08:48 AM
325xi front wheel bearing replacement LynnFlores M3 5 04-07-2006 04:47 PM
Wheel bearing wulley1 E36 7 04-07-2006 11:00 AM
