Unread 08-08-2007, 07:59 PM   #16
Dan
Title: Visiting Mod
Your Ride: 540
I <3 Autozone
Believe it or not, Autozone's Online is great to get part #'s for what you need and the price is pretty good too.
www.autozone.com
ie as previously stated:
i needed pre-cat O2's:
Oxygen Sensor $0.00 $61.99 2 $123.98
Brand: Bosch
Part Number: 13559
Application: Sensor located before catalytic converter
and free Fed-Ex ground shipping..
after taxes: $132.66
if you're going with a STOCK flywheel:
Luk / Flywheel
Manual Transmission
Warranty - 1 YR
DMF020
$383.99
^^ special order
So if you're looking for some OEM parts, shop around, of course, but do check with Autozone. they are everywhere and they can even special deliever the part to your local Autozone for pick up! they may not have the best prices sometimes but it doesn't hurt to check.
540i/6
Unread 08-08-2007, 07:59 PM   #17
Dan
Title: Visiting Mod
Your Ride: 540
just a FYI,
the holes under the rear deck is 80.5mm; i measured it with a dial caliper just now and if you want to use that to port any sound, make sure it's 80mm or less.. but not much. you got 2 of them anyways.
540i/6
Unread 08-08-2007, 08:02 PM   #18
scooter
scooter's Avatar
Rate My Car: 296 / 340
Your Ride: 99m3
great thread.
Unread 08-09-2007, 12:20 AM   #19
Chris
Chris's Avatar
Title: Visiting Mod
wow...
Unread 08-09-2007, 05:02 AM   #20
Wheel bearings
Glad to see you brought this over here to UB.c . . this subforum can sure use a boost
Front wheel bearings are another high wear item for E39's, and can deteriorate in as little as 60k miles. Diagnosed as a low rumbling sound with slight vibration or knockback on the brake pedal, particularly at slower coasting speeds. The same part number is used on all E39's except for the M5. Not too complicated of a task, and you can find a DIY at bmwtips.com.
Unread 08-09-2007, 12:34 PM   #21
dinan540
dinan540's Avatar
Pixels die on our displays. BMWNA will pay half the cost at dealerships if you twist their arm enough.
As for the radiator, I bought the zionsville super duty cooling kit and haven't had a problem after replacing 3 radiators, two overflow tanks and a water pump, ugh.
Also, valve cover gaskets are a common leak item and the valley pan. You can find great diy on www.e38.org. That is my next items to replace.
540i with some mods
Unread 08-09-2007, 12:34 PM   #22
dinan540
dinan540's Avatar
Yes an M5 LSD differential will fit on our cars, but you need the driveshaft, half shafts and the flanges to get it fit.
540i with some mods
Unread 08-09-2007, 12:35 PM   #23
dinan540
dinan540's Avatar
If you want light upgrades, pre-2001 models, best deal and customer service for lights is www.umnitza.com
540i with some mods
Unread 08-09-2007, 12:38 PM   #24
dinan540
dinan540's Avatar
If you want to free up more air flow, and you have a post-vanos 540 buy a 1997 540i intake manifold or a 1994-98 740i intake manifold. This works well if you have an engine modification chip. There is a rumor that the pre-vanos intake manifold is very similar in construction and engineering as the dinan intake manifold that sells for $1500 for the 540i.
540i with some mods
Unread 08-09-2007, 12:39 PM   #25
dinan540
dinan540's Avatar
Will springs and shocks fit from an M5?
Yes they will, but since the 540 is lighter, you will have the opposite effect of dropping your car, it will be even higher and look more gay!!!
540i with some mods
Unread 08-09-2007, 12:39 PM   #26
dinan540
dinan540's Avatar
Can the 740 18" M parallels fit on a 540i? No, not easily.
540i with some mods
Unread 08-09-2007, 12:40 PM   #27
dinan540
dinan540's Avatar
You can buy OEM M parallels in 18". On 2003 sport 540i models, they were standard.
540i with some mods
Unread 08-09-2007, 12:41 PM   #28
dinan540
dinan540's Avatar
Can M5 front calipers and rotors fit my E39?
Yes, they can, but they will only fit behind the M parallels. Other 17" OEM wheels, they won't fit behind, not enough clearance.
540i with some mods
Unread 08-09-2007, 12:43 PM   #29
dinan540
dinan540's Avatar
Can the M5 front and rear sway bars fit a 540?
Yes they can, a diy is on www.e38.org. The rear is easy, 4 bolts. The front is a huge pain in the ass. The M5 and the 540 sway won't fit the six cylinders.
540i with some mods
Unread 08-09-2007, 12:44 PM   #30
dinan540
dinan540's Avatar
If you want to free up some exhaust note and weight, get rid of the resonator and replace it with a straight pipe. www.supersprint.com sells them for $200 or most exhaust shops can fabricate one for you.
540i with some mods
E39 Baller Radiator dinan540 E12, E28, E34, E39, E60 6 01-06-2009 08:50 AM
1997 BMW 540i E39 Part Out! ruskiepatzan Bmw Cars For Sale/Wanted 1 01-22-2007 06:53 PM
favor to ask E39 owners w/ bluetooth... bimmerZ5 E12, E28, E34, E39, E60 1 01-12-2007 05:48 AM
