Unread 08-02-2007, 05:07 PM   #1
4loanman
Your Ride: 1999 740i
740i help please
I have a broken fog light and a replacement for it. However I cannot see how to remove the old fog light unit.
Also can someone tell me where the crankshaft sensor unit is located. I need to replace that also. All help is appreciated.
Unread 08-02-2007, 05:10 PM   #2
Chris
Chris's Avatar
Title: Visiting Mod
Hmm.... lemme go flag down mullet or witeshark, they'll be able to help you out with the fog light issue. I know in the older E36's you pulled the fog light out from the inside of the bumper to replace it. if memory serves me right, thats how the 740's work too. try that, and if that doesn't work.... i'll drive out there and yank it out for you
as for the crankshaft sensor, lemme look around a bit and i'll get back to you on that in the next ten minutes or so.
Unread 08-02-2007, 05:20 PM   #3
4loanman
Thank you for a quick reply. Can you clarify "from the inside of the bumper " ? I'll look at it tonight. Thanks.
4loanman (Don)
Unread 08-02-2007, 05:26 PM   #4
Linds
Linds's Avatar
Rate My Car: 70 / 340
Your Ride: 97 M3
Send a message via AIM to Linds
Well, on the e36's, there is a hole on the bumper on the side of the foglight closest to the middle of the car (inside the brake duct). If you stick a screwdriver in there, you can unpop the part of the bracket holding the foglight in the bracket. This lets you slide only the foglight out.
Unread 08-02-2007, 10:33 PM   #5
TerryY
TerryY's Avatar
Rate My Car: 7 / 340
Crank position sensor is just about straight down following the oil dipstick tube. I believe that the wire passes behind the tube.
One cap screw holding it in.
Spacing between the sensor and the flywheel is semi critical. If there is a spacer reuse it, if not don't worry about it unless it doesn't run after the new sensor is installed. I believe it is supposed to be 1 mm between the sensor and the teeth on the damper.
Terry
Aloha Oregon
'95 840
'98 SVT Cobra
Unread 08-02-2007, 10:41 PM   #6
RSF5
RSF5's Avatar
Rate My Car: 278 / 340
Your Ride: NOOTHHHIIIINNG
I've replaced fogs on my dads 99 740i, you just simply pops the unit out from the side carefully with a flat screwdriver and it pulls out, but do it carefully.
Unread 08-02-2007, 10:45 PM   #7
umnitza
Rate My Car: 94 / 340
there is a hole right next to the fog light on the lower section on the inside towards the grill.
use a thin long flat head screw driver, just push, the fog will literally pop out.
Look at those two holes, use the top one.
Unread 08-24-2007, 11:38 PM   #8
rrr
Your Ride: 95 740i
If you need more details, go to e38.org. I believe I saw procedure w/photos there.
I need to replace one, too. Where are you getting yours and how much?
Unread 11-27-2007, 10:01 PM   #9
mgood
Your Ride: 95 m3 / 95 740
yes, e38.org - good writeup / pics etc.
Just bought a 94 740i litespan 7 Series (E23, E32, E38, E65, E66) 20 03-04-2008 06:00 PM
740i Vs. 318i Photo Shot. TJsBimm Bimmer Showroom 8 01-30-2008 02:44 AM
Pics of my 94 740i litespan Bimmer Showroom 5 12-09-2006 03:27 PM
740I tranny shifter problem rjleee1 7 Series (E23, E32, E38, E65, E66) 2 11-15-2006 06:19 PM
Hi There. Newbie with a 740i. Wild William Introductions and Greetings 8 07-18-2005 06:43 PM
