Unread 05-20-2005, 12:08 AM   #1
pyro
instrument cluster and heater controlls...
Hi,
my instrument cluster dosn't light up at night and i cant figure out what is causing it... i repplaced the dimmer swich and all of the bulbes in the instrument cluster... nothing iluminates at all... need some help
Unread 05-20-2005, 01:16 AM   #2
breden
Rate My Car: 36 / 340
did you try the fuses?
Unread 05-20-2005, 05:16 PM   #3
pyro
that was the first thing i checked and none of em are blown i even rapplaced all of the fuses with smart fuses
Unread 05-20-2005, 09:52 PM   #4
I had the same problem and it ended up being the fuse... if you've checked that and it's not it, maybe the bulb behind the cluster?
And the obvious, check the dial for dimness to make sure you didn't hit it and knock into it all the way dim.
When I had my problem before I knew it was the fuse, someone suggested the headlights switch. If the connection is getting bad, it might not touch that part correctly, but still turn on the headlights. This is a bit far out I think, but it was suggested to me.
Anything beyond that is probably an electrical issue. =/
Unread 05-21-2005, 04:20 PM   #5
pyro
well iv checked and its not the swich or the dimmer its a short somewhere... so what color is the wire that iluminates everything? what is supost to be ilumintated so i can check if maby a wire is lose causeing it...
Unread 05-29-2005, 12:38 PM   #6
pyro
well still no luck any more ideas...?
