Unread 07-26-2007, 09:33 PM   #1
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 131 / 340
oil consumption
i know engines are supposed to consume a bit of oil over time. but lately, my M20 seems to be consuming a lot. today it needed a quart.
its last oil change was 1200 miles ago. before this last oil change, it needed two quarts in the 3k miles between oil changes. there is no leaking or smoking of any sort. but im gonna pull the plugs tomorrow and see how they look. hope the rings and gasket are ok.
in my last E30 i would need a quart between oil changes, but that was just before oil change time, and that engine had a leak. so what is going on here?
i guess i do drive it particularly hard. my bentley says that BMW consideres it excessive if it needs a quart every 390 miles. above that, its fine.
thoughts or ideas?
Unread 07-26-2007, 09:44 PM   #2
Sounds fishy. Like when I have a problem and overlook something... which I do a lot, sadly.
Let us know what the spark plugs tell you.
Unread 07-26-2007, 10:11 PM   #3
My car started using more as I got near 165,000 or so. After an overheat and rebuilt cylinder head, I'm not sure how it's doing cause I don't drive it much. But when it started, it was as mysterious as you seem to find yours
Unread 07-26-2007, 10:11 PM   #4
u know..i think its normal.
I say this because my 330 has ate a quart and a half one one oil change when i drove it like a monster. Otherwise she doesnt drink any. No leaks anywhere and no exhaust smoke what so ever.
318 on the other hand has never taken any oil. Except when i ran 5-30 by accident and it didnt like that.
I went to the dealer and asked them about the car taking oil, theey said it was normal for bmws to take about a quart.
but i would still check things out.
Unread 07-26-2007, 11:19 PM   #5
elsabor67
elsabor67's Avatar
Rate My Car: 35 / 340
Mine eats about a quart between changes. Barely anything over that and I drive it hard. I'll ask my partners over here and see what I get.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Unread 07-26-2007, 11:53 PM   #6
bill@bimmerclinic.com
bill@bimmerclinic.com's Avatar
Your Ride: Couple M3's
Whats the weight and brand of the oil your using?
Unread 07-26-2007, 11:57 PM   #7
RSF5
RSF5's Avatar
Rate My Car: 278 / 340
Your Ride: NOOTHHHIIIINNG
I rarely lose any oil in between changes (maybe I'm lucky), but I wouldn't think it to be normal to lose more than a quart but it sounds like you could be normal, how old is your engine?
Unread 07-27-2007, 01:03 AM   #8
celsdogg
celsdogg's Avatar
thanks everyone.
its 5w-30, non synth. i have almost 160k on it now.
i changed the plugs about 10k miles ago. when i pulled those, they looked great, and im not expecting the current plugs to be any different.
Unread 07-27-2007, 01:10 AM   #9
Might be time to do this.
http://www.blackstone-labs.com/
Unread 07-27-2007, 01:10 AM   #10
RSF5
RSF5's Avatar
Originally Posted by celsdogg
thanks everyone.
Should just be normal then with an older engine. It doesn't sound like its causing any significant difficulties.
Unread 07-27-2007, 02:51 AM   #11
I'd be using a little heavier wt oil this time of year (especially if you're running non-syn) try using 10-30. A quart of non-syn in 3500 is normal. Plus you mentioned you're driving it harder that could be a contributing factor.
Unread 07-27-2007, 06:31 AM   #12
I used to lose about a quart per 4k in the old 325i. 5W-30 at 160k is pretty thin. A car can still burn a good amount of oil without much detection. I would concur with c1's recommendation, go to 10W-30 and see how the car adjusts to it.
Unread 07-27-2007, 02:37 PM   #13
celsdogg
celsdogg's Avatar
ok, here they are. the number 5 spark plug smelled strongly like gas while the others were all faint, and none of them smelled like burning oil. the number 6 plug had a bunch of heavy grease around it, it was weird.
they looked fine when i had them out, but they look worse in the photos.
thoughts?
Unread 07-27-2007, 03:29 PM   #14
celsdogg
celsdogg's Avatar
just for reference, here is the previous set of plugs. changed late last year.
Unread 07-27-2007, 03:50 PM   #15
In person, does plug #1 look very white in comparison to plug #4?
Also, I've heard that oil (on #6) can find it's way above the spark plug. Personally, I've never had that problem, but a DIY on Pelican Parts says that it's not necessarily a huge deal.
For reference, I always use Mobil Clean 5000 (10W-40). I change my oil every 2500 - 3000 miles. My car has 146,000 miles on it and the car burns absolutely no oil, but then again, that could be an M42 thing.
Edit: Can I ask why you changed to Bosch +4 plugs?
Burning Oil Mercenary(FH) E36 12 05-19-2007 09:24 PM
