Unread 07-17-2007, 08:00 AM   #1
lukenicoll
Your Ride: 5 Series E39 1999, 530D Tourer
Windscreen Wiper Problem
Hi
One day while it was raining quite heavily the windscreen wipers just stopped in the parked position.
Since then they have not worked.
- The rear wiper works
- all of the washers work
- from what i can tell the wipers don't try to move - ie don't seem to be stuck.
I have checked the fuse which is fine.
My local garage have had a look at it, they couldn't find the fault, they said the motor is fine and basically i would be better getting a auto electrician to look at it.
I believe if it is a relay or something similar i can replace it my-self.
So i am looking for your ideas of what might be wrong!
Unread 07-27-2007, 01:05 AM   #2
BMW5820iA
Your Ride: 91' 520i 24V
Send a message via Yahoo to BMW5820iA
The wiper motor has a few contact plates which control the speed of wipers. If they are bented or damaged the wipers will hold up in position.
The fuse and the electric motor will be OK, but ...... no muvement.
Unread 07-27-2007, 01:19 AM   #3
bill@bimmerclinic.com
bill@bimmerclinic.com's Avatar
Your Ride: Couple M3's
Find a shop that has the diagnostic tools that can test modules. (autologic, gt1, carsoft) If your local to NJ I could help you out. This will also allow them to find out if its 1. the switch 2. the module 3. the motor
check this out for a local mechanic
http://www.bimrs.org/
Unread 07-30-2007, 03:29 AM   #4
lukenicoll
Thanks for your help guys - it was the relay!
Fixed it now!!
Windshield Wiper Problem bimmerdad E12, E28, E34, E39, E60 25 04-28-2012 03:11 PM
A Known Instrument Cluster Problem KickingKing E36 6 11-16-2011 09:50 PM
Might have a problem with my dealer nick_318is E21, E30 2 03-24-2006 12:54 AM
