Unread 07-01-2007, 04:48 AM   #1
Silvercat
Your Ride: 320SE 1994
Daytime Running Lights
I've just imported a 1993 E36 into Finland. Daytime Running Lights are required by law. Not difficult to do with a couple of relays and a splice or two. BUT - is the car already wired for this anyway does anyone know?
Unread 07-01-2007, 05:20 AM   #2
No. Daytime running lights weren't available on the early models.
Unread 07-01-2007, 06:11 AM   #3
denyo77
denyo77's Avatar
Rate My Car: 198 / 340
Your Ride: 1988 325i Touring
why not just turn on your normal lo-beams?
Unread 07-01-2007, 07:56 AM   #4
Silvercat
Non perfect memory leads to automatic fines - expensive!!!!!!!!
Unread 07-01-2007, 08:02 AM   #5
If you have ellipsoid headlights, I'm pretty sure there is a socket for the bulb built into the high beam reflector. At least that's how aftermarket Depo's are made. But you may have to run wire from the headlight socket.
Unread 07-01-2007, 08:33 AM   #6
denyo77
denyo77's Avatar
well then just put a post-it tag on the steering wheel or the speedomiter
Daytime Running Light install newsong Lighting 1 03-03-2007 02:26 PM
Daytime running lights DEATH2000 E36 3 07-31-2006 08:38 PM
