Unread 06-27-2007, 02:15 AM   #1
Jami318is
Jami318is's Avatar
Your Ride: 1991 318is
Question Cold idle vs Running idle
I am having a fun time with the idle on this m42. If I set the idle when cold to run good it ends up around 1000 to 1200 when the engine reaches running temperature.
If I set it when it is hot or at running temp at a fair idle around 750 to 800 it is way too low when cold and wont idle for crap.....
I found a vacume leak and once I fixed this leak it got worse.....right now I have a pretty good cold idle and when hot is is around 850 to 900 and seems ok....
any thoughts?
Thank You
Jami......Oh and that is not my car...Just a thought on the new paint.
Life without a bimmer is No life at all
Unread 06-27-2007, 06:00 AM   #2
any thoughts?
Thank You
you have more vac leaks if fixing one made it worse
Unread 06-27-2007, 01:31 PM   #3
Jami318is
Jami318is's Avatar
I think I was too tired when I wrote this post. Once I fixed the vacume leak. ( pressure regulator to throttle body) the idle became worse. I have re-adjusted things to a place that is working but I still have 2 different idles. Low when cold and higher when hot...Backwards if you ask me.
I have been looking for other leaks and found nothing...
She is very well but I know this can not be right about the idle.....
thanks
Jami
Unread 06-27-2007, 01:56 PM   #4
you are correct my friend - that is backwards. Check all your vac lines with a magnifying glass if you have to and the bellows tube/hose - before making those adjustments (I know, now we tell you) but the symptoms you listed point at a vac leak, a ICV dirty and/ or a loose gas cap. Even a possible fuel filter problem - sorry to be the messenger of grim news but I think you'll find it shortly.
Idle vibrations E39 540i lacikam E12, E28, E34, E39, E60 15 10-24-2011 11:47 PM
E36 320 Runs badly When Cold lesyoungman E36 9 05-17-2007 05:02 AM
325i Idle Control Valve Jammer3 E21, E30 1 07-14-2006 09:29 PM
Rough Idle + CEL Rooz E36 5 03-22-2006 10:30 PM
Computers - 57 Processes running.. brien4787 Geek Chat 4 12-10-2005 01:05 PM
