Unread 05-30-2007, 09:37 AM   #1
jonni325
Your Ride: 1995 325 IS
Window Motor replacement ????
Going to replace the window motor, drivers side tonight.
I have no problem doing the change out, but my question is should the window be up or down when I plug in the wiring, what tells the motor to stop at the bottom or the top? are there limit switches at the top and bottom? the motor is the type that drops a inch or so when you open the door and goes back up when the door is closed. I know how to initialize the window once it is in, I was just concerned for the first time power up of the motor. The old motor (now in peices) looks as though it had a type of encoder on to to monitor the windows location.
Anyone do this before?
Jon
Unread 05-31-2007, 11:26 AM   #2
jonni325
Well the motor replacement was not to bad, put to motor in and plugged in the wires and it would only go down, just a click when the up button was pushed,
I took an old cord that plugged into the ciggarette lighter and put some female crimp ends on it and them wired to the motor and ran it to the top. Then closed the door and ran through the initialization sequence and done, it worked perfectly,
Drops the 1/2 inch when the door is open and closes the 1/2 inch when the door s closed. After not getting any response to this issue, If I can be of help to anyone else doing this feel free to ask.
Unread 05-31-2007, 01:07 PM   #3
why don't you write up a complete DIY and submit it? I'm sure the members would appreciate your efforts
Unread 06-23-2007, 04:21 PM   #4
Sean76
Sean76's Avatar
Your Ride: 1995 325is
I would like to know exactly how you did this, my 325is is sitting outside right now with the door panel off and I cant figure it out, lol + it is starting to rain, thanks
Unread 08-07-2009, 04:27 AM   #5
kinezool
Your Ride: 94 - E36 318IS
this helped me a lot!!! i took off one of the plugs (the one with 3 cables) and the window went down only even I plugged it back. I tought I have to make pieces out of my door to fix back. Thanks a lot!
Is this the infamous window regulator problem? spicytuna E46 3 11-11-2007 01:34 AM
window is possessed! txitalian E36 4 04-07-2007 02:41 PM
rear blind help Chris E36 1 05-23-2006 09:09 AM
front window motor brien4787 E36 9 02-09-2006 12:29 AM
WTB driverside window regulator for e36 vegas mikey Bmw Cars For Sale/Wanted 10 11-10-2005 11:50 AM
