Unread 05-29-2007, 01:00 PM   #1
Boxer19
Boxer19's Avatar
Your Ride: 2001 525i
Power Steering Hose leak
Has anyone changed out the PS hoses from the reservoir? It's leaking down the hose onto other hoses, bottom pan and making a mess although I haven't noticed any fluid loss yet. I was going to add an extra hose clamp to the crimped on one but looks like not enough room. Maybe I should remove the OEM hose clamps and just replace with a screw type clamp. 2001 525i.
Ever stop to think and forget to start again
Unread 06-16-2007, 08:16 AM   #2
Boxer19
Boxer19's Avatar
As I searched this I found the answers on another forum. Kinda disappointed no one here bothered to reply but I understand it is a common problem.
Unread 06-16-2007, 08:18 AM   #3
On my car the hoses were leaking like sponges. I replaced them all
Unread 06-16-2007, 09:29 AM   #4
Don't take it personal, folks here won't throw suggestions out if they're not a high% of being correct. Most would rather not mislead you when trouble shooting or fixing a problem. Plus a majority of the members are college kids with E36s and 3 series and not 5s & up. And to my knowledge it's not a major issue (and I worked for BMW NA)
Unread 06-20-2007, 04:52 PM   #5
Boxer19
Boxer19's Avatar
I didn't take it personal c1apton and thanks for your comments. I suppose I wouldn't give a wrong answer just to answer either. I was able to fix my problem with a new hose but there was a little more to it than I expected. If anyone needs help with this please email me. BTW I'm waaaay past college age but this is my first 5 series and just a touch different than some 3's.
Unread 06-20-2007, 04:55 PM   #6
Boxer19
Boxer19's Avatar
After getting into replacing the one, I should have done all of them like you did. And, you're right, they were like sponges.
Unread 07-27-2007, 02:40 PM   #7
dinan540
dinan540's Avatar
Happened on my 540, except I didn't notice immediately and I fucked up the pump. So, I had to replace the pump and all of the hoses.
540i with some mods
Unread 07-27-2007, 03:01 PM   #8
bill@bimmerclinic.com
bill@bimmerclinic.com's Avatar
Your Ride: Couple M3's
Most of the time its just the oem crimp clamp that loosens up. If you have the right tool you can tighten it or better yet cut it off and replace it with a good german made screw clamp.
Unread 07-27-2007, 04:31 PM   #9
On my 1993 318is, I believe the power steering hoses are leaking. Is this a hard job to do? Do I need to drain the fluid? What fluid do I use? Is there anything that is connected to the power steering system that I would be messing with?
I'm pretty sure this has been happening (in a small amount) since I bought the car 3 years ago. I've had no power steering loss, but definitely cannot afford a broken pump.
Unread 07-27-2007, 05:02 PM   #10
drz
Title: local dumbass
Rate My Car: 34 / 340
Your Ride: E36 2.8i
Amanda, for now just keep topping off the PS reservoir with ATF (yup, automatic trans fluid -- DONT use regular PS fluid from the store).
I have had mixed opinions about the replacement. Some people say it is just a matter of being able to get underneath the car -- others say that it is a royal pain on the behind. either way, yes -- you need to drain the fluid. I have all the parts to do it in my apartment, including all the clamps, nuts, bolts, and even a new reservoir -- I should be able to report back in the next few weeks.
Unread 07-27-2007, 05:32 PM   #11
Definitely let me know. Thanks Daniel. If not, I'll talk to you about it at MBF.
Unread 04-10-2012, 11:36 AM   #12
peatee07
Your Ride: 2007 BMW 530i
2007 bmw PS leak
<Hi I have a 2007 BMW 530i which has a minor leak with the power steering. Would you recommend having a shop repair it or diy? I've already tightened the hose but it seems to be leaking still, any suggestions?
Unread 04-10-2012, 09:31 PM   #13
The purpose of the board is to share information collectively not privately. The information is here for everyone to read. I've removed your email address for your protection against spam.
Replacing the hoses is the best option. The deteriorate over time and should be replaced. Tightening the hose is a temp fix.
Unread 04-11-2012, 01:29 PM   #14
peatee07
Thank you for your advice!
Unread 06-01-2012, 07:04 PM   #15
roadsterred
Your Ride: 1994 540i
A few years ago, I encountered a similar problem with my 1994 540i leaking power steering fluid. However, the leak was located at the steering box. Tightening the hose connections at the steering box did not stop the leak. It wasn't until I actually disconnected the hoses did I find that the factory compression fitting on one of the hoses was causing the leak. Replacing the hose solved the problem.
Power Steering Fluid Showing on the VDO Jimmie34 E12, E28, E34, E39, E60 4 05-09-2007 09:15 AM
Need help with a fuel hose leak Douglas E21, E30 6 04-26-2007 05:26 PM
Power Steering Loss-help!!! tonyvt328is Tire, Wheels And Suspension Forum 2 01-31-2007 09:33 AM
Power Steering Loss-help!!! tonyvt328is Tire, Wheels And Suspension Forum 0 01-22-2007 01:44 PM
Power steering leak witeshark E21, E30 15 03-10-2006 12:46 AM
