Unread 05-25-2007, 06:31 AM   #1
Boxer19
Boxer19's Avatar
Your Ride: 2001 525i
Creaking door
Does anyone have a creaking driver side door? Now that the weather is getting hot it is creaking....mainly when opening. It appears to be the flat bar that goes inside the door. I tried silicone, fluid film, even wd40. It is not the hinges. I have an E39 525i '01.
Ever stop to think and forget to start again
Unread 05-25-2007, 08:57 AM   #2
try a grease on the actual bar - there's also a bulletin out about the E34s' support (bar) that a weld on the inside can break & it needs to be re-welded by a body shop.
Unread 05-25-2007, 10:43 AM   #3
this happened on my brother's e46, he just sprayed a ton of wd40 on all the hinges and joints and it isnt doing it anymore
Unread 05-28-2007, 12:25 PM   #4
Boxer19
Boxer19's Avatar
Thanks guys, I used multi purpose grease (wheel bearing grease) and the problem was cured.
Unread 05-28-2007, 12:43 PM   #5
And if you don't like the color of white grease on your pretty black car, use synthetic grease, most of the times it's black.
EDIT:
<--- Why am I the "Destroyer of Worlds" ??
Unread 06-03-2007, 10:50 PM   #6
maximk2
Your Ride: 1993 325i
yea i actually had the same problem on my e36, and just a bit of castrol did the trick.
Unread 06-04-2007, 04:39 AM   #7
It automatically changes to that between 990 and 1000 posts, then it'll change to 'I live here'. But you can now change it to whatever you like on the User CP.
e46 driver door does not unlock beemermike E46 12 10-31-2008 05:51 PM
E46 Annoyances/Fixes Numark318i E46 5 04-27-2007 02:10 PM
E36 DOOR PANELS SWITCHED!!!! Teaser Pics/DIY coming soon! delmarco E36 22 06-22-2006 02:03 PM
Driver 's door key lock problem singring E36 2 12-29-2005 07:04 AM
Door lock issues kestrel325is E36 9 10-01-2005 09:17 AM
