Unread 05-21-2007, 02:57 AM   #1
PAULY
Your Ride: 1986 525e
86 525e
Please help me
the 525e has developed a bad miss on acceleration to the point now where its just stops and wont go.
have replaced coil, leads, plugs, distributor, fuel filter and pump, computer, 2 sensors at gearbox/engine, air flow sensor.
as the car warms up from cold it misses and stops and wont go again.
seems it looses spark as it warms up.
had this now for three weeks and no one can help me- except you guys, please.
Unread 05-21-2007, 06:05 AM   #2
check ignition wiring harness (not plug wires) it sounds like you have a wire(s) when they get warm the expand and lose contact. Use an ohm-meter to test wires after it warms up. Also check your ICV, they gum up and cause similar symptoms as you described. Dudesky did a fantastic DIY about it : http://www.unitedbimmer.com/forums/t...?highlight=ICV
86 735i stuck in 3rd gear RobTheOgre 7 Series (E23, E32, E38, E65, E66) 6 07-30-2007 02:48 AM
86 Cutlass Tranny Pregunta celsdogg Other Makes And Models 0 05-30-2006 01:05 PM
84 533/ 86 535 Drivetrain swap jonny E12, E28, E34, E39, E60 5 05-21-2006 11:58 AM
86 325e transmission kramer06 E21, E30 0 05-05-2006 05:15 PM
86 735 wheels Hoppy 7 Series (E23, E32, E38, E65, E66) 6 09-26-2005 03:26 PM
