Unread 05-11-2007, 03:29 PM   #1
Kasei
Kasei's Avatar
Your Ride: 1991 525i
Fog light question
Ok, I got my 525i in September 06. It wasn't until taking the last batch of pictures I post that I relized the driver's side fog light didn't work so I'm not sure if it happened while I owned it or before. I used this as an excuse to upgrade the bulbs. After I removed the fog lights and put in the new sylvania sliverstars I noticed that it still wasn't working. Then I was driving home and turned them on and swore they were both working, turns out the right light was just lighting up the left side enough to make it look that way.
How much will having it rewired cost?
Could it be anything else other then just bad wires?
Thanks for the help guys.
Unread 05-17-2007, 03:09 PM   #2
Kasei
Kasei's Avatar
Any help guys?
Unread 05-17-2007, 03:30 PM   #3
Corroded contacts maybe?
Unread 05-18-2007, 05:16 AM   #4
cainchapman
cainchapman's Avatar
Rate My Car: 127 / 340
Your Ride: 1995 540LE
Pull the lightsurrounds out and clean the contacts. It's very common to have poor connection at the fog lights.
Unread 05-18-2007, 06:00 AM   #5
Kasei
Kasei's Avatar
Should I use any special cleaner or just a towel and water? If they are corroded just replace them?
Thanks for the replies guys.
Unread 05-18-2007, 07:40 AM   #6
isopropyl alcohol and/or an electrical spray contact cleaner (and NOT WD40)
Unread 05-18-2007, 03:13 PM   #7
Kasei
Kasei's Avatar
I'll give it a try and hope for the best, thanks.
Unread 05-19-2007, 01:38 AM   #8
bmdude
Your Ride: BMW350
loose connections, poor grounding, burned bulbs are the uses causes why lights won't work..
DIY How to replace fog light bulbs on an E46 sedan Rooz BMW OEM Parts Department DIY's & FAQ's 7 10-20-2008 09:21 AM
fog light problem HELP! Tochenzo Lighting 6 10-10-2006 11:32 PM
Fog lights question witeshark Lighting 0 06-28-2006 02:03 PM
WTB; E36 fog light brackets M.C. Sketuls Bmw Cars For Sale/Wanted 0 11-15-2005 08:29 AM
my lonely fog light isnt so lonely anymore brien4787 E36 18 11-08-2005 12:53 AM
