Unread 05-07-2007, 02:38 PM   #1
Bella_Sicilia
Bella_Sicilia's Avatar
Your Ride: 00' 528i
Send a message via MSN to Bella_Sicilia Send a message via Yahoo to Bella_Sicilia
Exclamation 740iL...check Brake ?
So,
last week this message came on in the Check Control, it says check brake "something". ('97 740iL)
It seems like LIN?NES but I can't make out what it is and I'd like to know what you guys think (english is not my first language).
The break pads are fine, and we just replaced the rear brake pads, checked the sensors.
I hope the pictures are not too bad and you can help me.
Thank you in advance for youe help
Unread 05-07-2007, 02:54 PM   #2
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
Yeah, I've seen that before. Yes, it probably is your brake fluid. Did you change that too when you changed out the brake pads?
Unread 05-07-2007, 03:10 PM   #3
thats what it says when your sensor is triggered, make sure its connected properly, and there are two sensors, there is one in the front as well
Unread 05-07-2007, 08:46 PM   #4
It says "check brake linings" - if you just changed rear pads check to make sure the sensor didn't come loose or cut the wires. (I had the rear sensor wires clipped by a wheel weight on right rear rim) Also check your front sensor (left front)
Unread 05-09-2007, 09:50 PM   #5
NewBIMMERfan85
NewBIMMERfan85's Avatar
Your Ride: 1988 735I
yeah dont forget the front brake line wires too, my bimmer has on front and rear drivers side so see if the aint fraid if they are just get u a new set i dont think they cost that much.
E30 Brake Caliper problem..check yours. Numark318i E21, E30 6 11-10-2011 10:53 AM
Brake check light wb00 E21, E30 4 01-23-2007 10:53 PM
Check Brake and Fuel Lines 3050rpm E36 1 09-23-2006 11:51 AM
