Unread 05-07-2007, 08:31 AM   #1
Jimmie34
Your Ride: 1992 525i
Unhappy Power Steering Fluid Showing on the VDO
I have a 1992 E34. The VDO is telling me to go to the owners manual for a "Power Steering Fluid" message. Unfortunatly, I do not have the owners manual. I have serviced the car and reset the service. The power steering res. is full and the fluid looks clean and there are no appearent effects on the machanical functioning of the steering. It does make a slight pump cavitation noise.
Unread 05-07-2007, 08:58 AM   #2
Try bleeding the system. Turn from stop to stop SLOWLY and don't hold at the stops for more than 3 secs. Do that a couple of times then recheck your fluid level.
Unread 05-08-2007, 06:25 PM   #3
Jimmie34
I've tried bleeding the system when I replaced the brakes and rotors. I have found that not to help. I have looked at the schematics and do not understand what type of sensor is causing the VDO to display. I have seen suction hoses pull air into a hydraulic system without an external leak and I am beginning to think this may be the issue, but as stated previously, how is the ECM being told there is an issue? Pressure, Suction, or a float switch?
Unread 05-09-2007, 02:53 AM   #4
Does your car have the self leveling rear shocks? According to a friend in BMW NA, he mentioned that would show on the VDO if there is a leak or low fluid condition on cars w/ self leveling rear shocks.
Unread 05-09-2007, 09:15 AM   #5
Jimmie34
My car is without self leveling rear shocks.
Power Steering Loss-help!!! tonyvt328is Tire, Wheels And Suspension Forum 2 01-31-2007 09:33 AM
Power Steering Loss-help!!! tonyvt328is Tire, Wheels And Suspension Forum 0 01-22-2007 01:44 PM
Power steering leak witeshark E21, E30 15 03-10-2006 12:46 AM
Power Steering failure... Longhairedhippy E46 20 11-16-2005 10:30 PM
Power steering. catalyst E36 4 07-26-2005 12:04 AM
