Unread 12-03-2007, 05:15 PM   #16
bueras
bueras's Avatar
Your Ride: 2001 BMW 325ci
Caden,
I got your PM but couldn't reply ( you are currently not accepting PMs). Anyway, You can fit up to a 8.5 in the front with a 35-45 mm offset with no more than a 225/40/19 tire(225/30/20 for 20s). The rear is what you have to be worried about. You can fit up to a 9.5" but the key is to get it with a 40-45mm offset (i think M3 replicas are like 32+ mm offset). The key is get a higher offset so the wheel will tuck into the fender and will not stick out. You could always go for a 7.5" rim in the back. In any case however, I think you will have to do a little modification to your car.
Unread 12-05-2007, 01:43 PM   #17
caden
Your Ride: 2004 325ci BMW
Bueras,
Thanks for the 411. The 19s are on and they looked intense. The ride has changed though. My steering wheel feels heavier and doesn't feel as steady as when the 17's were on. Is this a common problem(s) with larger rims? Thanks. Caden
Unread 12-06-2007, 10:50 AM   #18
bueras
bueras's Avatar
Caden,
Your ride is going to be a bit rougher thats for sure. This is pretty normal for bigger wheels with smaller tires, nothing to worry about though.
Unread 12-06-2007, 03:28 PM   #19
denyo77
denyo77's Avatar
Rate My Car: 198 / 340
Your Ride: 1988 325i Touring
and the thing with the steering comes from the offset... b/c the bigger rims prolly have a slightly different offest, you've lost your negative roll radius (king pin offset)
OEM M3 18" Wheels Antiburn Wheels And Tires For Sale/Wanted 1 05-03-2006 08:08 PM
4 Stock 323is Wheels w/ Tires + Spare STEVE36 Wheels And Tires For Sale/Wanted 1 03-11-2006 08:57 PM
FS Locally: Stock 15" 325i Spare mpowerd Bmw Cars For Sale/Wanted 0 07-06-2005 07:24 PM
WTB WTT: 18" Wheels w/ Tires dopeyx27 Wheels And Tires For Sale/Wanted 0 05-12-2005 06:54 AM
