Unread 05-01-2007, 12:34 PM   #1
bimmerdad
Your Ride: 92 525i, 03 F150 Supercrew
Check Control
Hey Gang,
Loking for some help with the latest problem.
When i start my car, my seat belt light comes on in the Check Control display, then "Check Control" is displayed without any other information. Am i missing something? Shouldn't there be a fault displayed after "Check Control" to kinda lead you to what the problem may be?
My question then is, What is causing this and How can I fix it?
I have search and having seen anything that specific.
Bimmerdad
92 E34
Unread 05-01-2007, 02:20 PM   #2
when the "check control" comes up - there's a fault code that needs to be read. To read the codes - turn ignition to "on" and fully depressing accelerator pedal to the floor 5 times within 5 secs. The check engine light come on for 5 secs then start flashing the fault codes.
Unread 05-01-2007, 02:56 PM   #3
bimmerdad
You again... 8-)
Did that and came up with the code:
1444
Which I looked up and which indicates, "No More Faults".
Could I be missing something?
Oh and again Thank You for such quick responses...
Bimmerdad
92 E34
Unread 05-01-2007, 03:06 PM   #4
I don't know about the E34, but Check Control in the E36 has nothing to do with the CEL/fault codes Usually it will say "CHECK CONTROL OK". If otherwise, I think it must mean a malfunction with the unit or a sensor attached to it. Sorry, that's all I have
Unread 05-27-2007, 12:33 PM   #5
Jimmie34
Your Ride: 1992 525i
I have had the same problem with my car when something is left on or a door is not fully closed which leads to a dead battery in the morning. The ecm could possibly be reading a current draw, but I am still learning.
E36 DOOR PANELS SWITCHED!!!! Teaser Pics/DIY coming soon! delmarco E36 22 06-22-2006 02:03 PM
check control light Chris United Off Topic  **FOR MEMBERS ONLY** 5 06-16-2006 12:43 PM
