Unread 04-25-2007, 05:46 PM   #1
Douglas
Your Ride: 1991 318I
Need help with a fuel hose leak
Basically its a "can I fix this" question.
Ok. Got a 91 bmw 318i. The hose to the fuel filter has a leak. Not major, but enough to be a money waster.
Now the hose goes up into the floorboard (ill post a pic.) where I cant reach to. Is it feasable to cut the hose, put a connector (if such a thing exisits) and run new hose from the connector to the filter?
Heres a pic of the hose going into the filter.
http://img.photobucket.com/albums/v4...dor/filter.jpg
Heres the hose going up into the area I cant reach (its the one not surrounded by that foam)
http://img.photobucket.com/albums/v488/Glaydor/hose.jpg
Heres the floor pan thats covering where the hose is going
http://img.photobucket.com/albums/v488/Glaydor/pan.jpg
Any help would be appreciated.
Unread 04-25-2007, 06:14 PM   #2
RSF5
RSF5's Avatar
Rate My Car: 278 / 340
Your Ride: NOOTHHHIIIINNG
you would probably be better off replacing the entire hose. I'll see about how you can reach it.
Unread 04-25-2007, 07:27 PM   #3
Looks like you need Part #5 if I am interpreting this correctly, replace the whole line.
Here is the link for refrence too: http://www.realoem.com/bmw/showparts...45&hg=13&fg=10
Unread 04-25-2007, 07:54 PM   #4
Douglas
Yeah. Thats the part.
Found its not as difficult as it appears. just need to take off that plate (2 nuts and a screw) and I can swap the hose out. So I know what im doing this weekend, heh.
Unread 04-25-2007, 08:09 PM   #5
You might want to get something to close off the fuel line while you swap them (a cap of sorts). You should also disconect the battery and not have any open flames near it. Should be a pretty easy job.
Unread 04-25-2007, 08:37 PM   #6
Douglas
Yeah, ill get something to catch the gas. Also making sure I dont have much gas in there. And disconnect the battery as well
Unread 04-26-2007, 05:26 PM   #7
Douglas
Follow up question, how do I drop that pan? I got the bolts out and the nut loosened, but the pan will not budge. Tried tapping, and nothing. Am I missing something?
Fuel filter change akinthecat E36 12 08-19-2006 09:55 AM
