Unread 04-24-2007, 09:40 AM   #1
ardentfreaker
Your Ride: 97 BMW 328i Sedan
Exclamation Warning Lights on 1997 328i
If anybody knows a detailed description of all possible kinds of warning lights that appear on the panel (1997 328i), could you post it?
I have two couple of warning lights (follow the attachment) that are on now. 1st one, I was told indicates ABS failure. Not sure about the second one.. could anybody let me know. Thanks
Also, any links to download a service manual??
Click image for larger version
Name:	warning signs.JPG
Unread 04-24-2007, 07:31 PM   #2
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
2nd is breaks. Most likey break pads.
Is the 2nd one orange or red on your dash?
Unread 04-24-2007, 09:23 PM   #3
215BIMMER535
215BIMMER535's Avatar
Rate My Car: 123 / 340
Your Ride: '97 328i
yup second one is pad wear sensors, dont worrry they're 10 bucks a piece and a snap to replace (especially while you're replacing your pads. the first one is in the same row as the pad wear light correct?
Unread 04-24-2007, 11:20 PM   #4
ardentfreaker
Its red. Thanks
Unread 04-24-2007, 11:22 PM   #5
ardentfreaker
No, the first one .. the warning sign with an exclamation is in the center, one row higher than that of the second sign.
So, do I have to change the pads and also the sensor? Thanks in advance 215Bimmer.
Unread 04-25-2007, 12:02 AM   #6
first one is traction control?
Unread 04-25-2007, 01:26 AM   #7
drz
Title: local dumbass
Rate My Car: 34 / 340
Your Ride: E36 2.8i
Did you not get my PM about 12 hours ago?
You can download teh Bentley Service Manual here
Yes, you will need to replace the sensor. You would not have needed to do that if the brakes had been replaced before the light had gone off, however.
(for your car, just think ASC+T instead of DSC)
Originally Posted by drz
There is no electronic version of the E36 manual. BMW started providing the manual online for E46s and newer...
The first light, if surrounded by an open circle with an arrow tip on one end, is your ASC+T (Automatic Stability Control + Traction) light. It will be on whenever you have disengaged ASC+T (via the green button in the center console); it will illuminate intermitently whenever the ASC+T kicks in; or it may be indicating an ASC+T failure.
The second light is the brake pad wear sensor. If the light is on, your front pads, or rear pads, or both need to be replaced very soon.
Best of luck with the BM, and welcome to werkz.
1995 Dinan M3 & 1997 328i komodo Bimmer Showroom 11 03-23-2006 07:22 PM
A question about pre 1997 and post 1997 E36 seats! delmarco E36 4 08-20-2005 04:39 PM
