Unread 04-22-2007, 10:31 AM   #1
Hazman555
Your Ride: 2001 325se touring
Unhappy Ignition failing to come on
Just got a 2001 325se touring.
Really happy with it apart from a problem which is now getting worse and worse. The ignition is failing to start when the key is turned to the number 2 position. The airbag light comes on and radio and windows work on number 1 but when I turn to number 2 nothing changes. Have tried with both keys just in case it was a key problem.
I have to keep trying until all of a sudden it will all fire up as normal.
Hope some one can point me in the right direction.
Unread 04-22-2007, 11:35 AM   #2
maybe a battery. Although the smptoms for that is headlights flashing and starter clicking.
does your Check Engine light come out after you start it up?
If so take the car to a oil change place(like oil changers 3000 or something) and get a free OBDII code reading.
That might give you more answers.
Unread 04-22-2007, 03:09 PM   #3
Hazman555
Battery is all fine.
When the ignition does finally come on and I then start the car it all runs fine and their are no warning lights.
Think hooking it up to the computer is the next step.
Unread 04-27-2007, 02:03 PM   #4
Hazman555
Got it sorted.
Just in case anyone is getting the same problem it was the ignition switch. Simple really
Unread 07-08-2007, 03:56 AM   #5
MR C.
Your Ride: 99 BMW 323 CI SE
Thanks to your help and a new ignition switch my car is now sorted, i had the same problem but it started with just the abs light not coming on. cheers!!!
Unread 07-27-2011, 01:08 PM   #6
diet
Your Ride: bmw coupe e36 1999
hi i have the same problem everything works until you try to start it when you say ignition switch do you mean the barel or is the switch different ?
Unread 07-29-2011, 11:57 AM   #7
diet
mine started working again now but I changed the switch anyway so hopefully shud have no further problems
Unread 09-04-2011, 03:06 PM   #8
mathabza
Your Ride: 2003
I have the same problem too. my everything switches on but doesn't crank and there's no beeping sound when key is in the ignition. any advice on DIY?
Unread 09-20-2011, 12:57 PM   #9
diet
in the post above all the problems hav bin ignition switch so i wud try that first or get garage to test it
Ignition Lock Removal falcon900 E36 0 03-21-2007 03:48 PM
Plasma Ignition System Rooz E36 3 03-15-2006 11:13 PM
Need DME Ignition Transistor singring E36 1 12-15-2005 11:28 AM
