Unread 04-18-2007, 10:56 AM   #1
kevinl34
Your Ride: 1994 325is
325is climate control problems!!!!!
have a 325IS well the climate control is acting crazy while the car is running with the lights on the the climate control will work the a/c button defrost etc. but once I cut the lights off the the unit stops working samething while driving but it will work for a while then shut off with or without the lights on. Now suggestions my machanic says it might be the harness because the climate control unit was replaced with a new one and both done the samething has anyone ever had his problem? Also with effect the heat? could it be the harness?
Unread 04-18-2007, 01:04 PM   #2
What lights? The interior lights? The headlights? A flashlight?
Do you have digital climate control or analog?
Pics?
I can't really help because it's so general.
Unread 04-19-2007, 09:32 PM   #3
kevinl34
climate control
I'm refering to the light on the climater control itself everything else far as other lights are fine.
Unread 05-03-2007, 02:13 PM   #4
stevo
Your Ride: 1997 318se Touring
Take a look here
http://www.unitedbimmer.com/forums/e...l-failure.html
Unread 05-03-2007, 04:01 PM   #5
BaLAnCe17
BaLAnCe17's Avatar
Your Ride: 1998 m3 coupe :-D
Send a message via AIM to BaLAnCe17
word
Repairing climate control unit SHAHAB323IS BMW OEM Parts Department DIY's & FAQ's 16 08-18-2010 05:22 PM
Help, I have serious electrical problems... please. mullethunter3 E36 12 01-19-2006 01:02 PM
Fix your analog climate control backlight Dudesky BMW OEM Parts Department DIY's & FAQ's 1 11-06-2005 09:01 PM
Fellow BMW owner needs Carfax, can anyone help? ilia BMW General Discussion 2 05-05-2005 06:51 AM
