Unread 04-15-2007, 10:09 AM   #1
NewBIMMERfan85
NewBIMMERfan85's Avatar
Your Ride: 1988 735I
Unhappy Car Cranks but wont start?
Ok i was going out to a friends house and suddenly the car started to rev down to 2000 rpm and sputtering i pulled over and it died . the check engine ligth came on so i look around the online thing i found a was a broke vacuum line and go it connected then it started again the did the 2000 rpm sputter. Then the gauges on my car goes crazy they started moving back and forth then it stops, now the gas gauge niddle is pointing way south ? Any Ideas
Unread 04-15-2007, 10:54 AM   #2
is your charging system ok? does the car crank well(like fast, or is it kinda slow)
Unread 04-15-2007, 11:16 AM   #3
NewBIMMERfan85
kinda slow cause after cranken a few time the car gets weak
Unread 04-15-2007, 11:22 AM   #4
NewBIMMERfan85
if its the charging system what should i look around for?
Unread 04-15-2007, 11:33 AM   #5
well see i fyou can start the car first by jumping it, then look to test if the alternator is charging the battery
Unread 04-15-2007, 03:23 PM   #6
NewBIMMERfan85
ok the charging seems fine, and we double check for the pump and its not working, i think it burnt out cause i found out that, the vacuum hose was to the fuel pressure regulature i belive and it made it work to hard a burnt the pump out is that possible?
Unread 04-15-2007, 03:25 PM   #7
NewBIMMERfan85
also did u ever have you indicator read out in german instead of english
Unread 04-15-2007, 06:50 PM   #8
NewBIMMERfan85
dude wheres the fuel pump relay located?
Unread 04-15-2007, 10:04 PM   #9
NewBIMMERfan85
Car Crank Prob Again
Ok the car just ticks now and wont crank at all and i found the fuel pump relay and it only clicks once so i assume that it bad so why does it just tick while it starts?
Unread 04-15-2007, 10:37 PM   #10
umm, clicking is your starter relay, not your fuel pump relay, fuel pump you will just hear a little humming/buzzing/whirring when you turn the key, did you say ur battery is good?
Unread 04-15-2007, 10:51 PM   #11
NewBIMMERfan85
ok the the fuel pump relay has the little diagram made on it right
Unread 04-15-2007, 11:07 PM   #12
NewBIMMERfan85
ok batter is weak for sure like the starter just ticks and the like sensor before the throttle bottle humms, i got it to crank but it started ticken again so im sure the battery my be going bad. So could it not be holding a charge and not be enough to lets say run the fuel system correctly?
24 01-22-2008 05:54 PM
Car not switching on, self works but doesnt start the car, plz help guy... djfactor E12, E28, E34, E39, E60 3 11-09-2006 07:08 PM
MAJOR PROBLEM - Starting Car!!!! HELP!!! projal147 E36 12 09-07-2006 11:18 AM
Car wouldn't start??? EnvyM3 E46 6 01-05-2006 05:45 PM
