Unread 04-12-2007, 12:29 PM   #1
steve doran
Your Ride: '97 E38
E38 door lock problem
Hi guys, hope someone can help me out with this! Last year the drivers door wouldn't open, I took the car to the main agent, they bent me over and shafted me for 400 to open the door and fit a new actuator.
This time, it's the front passenger door with a similar problem. I managed to remove the outer handle and unclip the actuator, it seems to be working fine. I assumed that if the actuator is removed, the door would open if the two levers on the lock assembly which slide inside the actuator are in the correct position?
Not So, the door won't open, I'm thinking that the lock is broken inside? Grateful for any wisdom on the subject.
cheers
Steve Doran
Unread 04-12-2007, 01:29 PM   #2
TerryY
TerryY's Avatar
Rate My Car: 7 / 340
Not many 7 owners here.
Have you asked here: http://the7seriesregister.co.uk/Main.html
Terry
Aloha Oregon
'95 840
'98 SVT Cobra
Unread 04-12-2007, 03:28 PM   #3
Bubba
E38 door
On my E32 it was a cracked door lock actuator bracket that was the culprit. I removed door panel and welded the bracket and that solved the problem. Go to http://www.e38.org or http://bmwe32.masscom.net and check thee for repairs.
Unread 05-14-2007, 06:10 PM   #4
rjk740
Your Ride: 95 740i
have just had my 95 740i door fixed - problem was in the LOCK; key would not turn it, door only opened from the inside, new lock and mechanism installed
A Known Instrument Cluster Problem KickingKing E36 6 11-16-2011 09:50 PM
Bmw 728i E38 Audio/sat Nav Problem sul1987 7 Series (E23, E32, E38, E65, E66) 2 12-27-2008 05:41 PM
