Unread 04-05-2007, 12:35 PM   #1
jonni325
Your Ride: 1995 325 IS
Left side rear wheel clunking noise ??
Just put new tires on all around, Proxies were to loud. Now I hear a clunking noise from the left rear when turning to the right, speed of the clunking noise varies with the speed of the car. Straight line and left turns are fine, only right turns, Tires are balanced fine and the rims are not bent.
Possible rear wheel bearing?
Thanks for any help you may have.
Unread 04-05-2007, 01:03 PM   #2
Wheel bearing is my 1st thought, what do you mean with a clunking noise? Migt want to take off the suspected wheel and take a look around and make sure nothing looks wrong.
Could this also be a strut or worn shock mount?
Unread 04-05-2007, 01:10 PM   #3
jonni325
Its a audible dunk,dunk,dunk, varing with speed, even the slightest turn to the right brings it on, can hear it more in the back seat left side rear, I put the rims on the car myself, did do a look around but will pull it off tonight and check again. whats the best way to determine if it is the bearing?
Unread 04-05-2007, 01:19 PM   #4
might be shock tower mount?
my mechanic just turned that wheel bearing seperatly and listened to it. Made a slight grinding noise when my bearing was out.
Unread 04-05-2007, 04:02 PM   #5
elsabor67
elsabor67's Avatar
Rate My Car: 35 / 340
I had a noise like that on my German Specs E30 and it turned out to be my subframe bushing (severe pain in the butt). I'm not well versed on yours but if you have subframe bushings, check those too.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Unread 04-05-2007, 05:36 PM   #6
RSF5
RSF5's Avatar
Rate My Car: 278 / 340
Your Ride: NOOTHHHIIIINNG
brushings, shocks, bearings. Could be those. Could be something else.
Unread 04-05-2007, 07:50 PM   #7
yea maybe the rear shock mount, its a common problem with an easy fix(they arent too bad, just hope that is what the problem is)
Unread 04-06-2007, 03:59 AM   #8
chimp
when the shock mount went on my E30 m3 it was more of a sqeaking sound coming from the rear.
Unread 04-06-2007, 04:21 AM   #9
double check & make sure your left rear wheel is seated properly against rotor - flush. If they hang up on center lip it can put excessive pressure on lugs. (it's something really easy to overlook)
Unread 04-11-2007, 11:18 AM   #10
jonni325
Thanks for all the suggestions,
I jacked it up and can wiggle the rear tire about 2-3 mm also a noticable noise when I rotate the wheel, so I am pretty sure the bearing is scrap, I will be tackeling that tonight as the parts have come in, and I bought the proper tools to do the job.
Will let you know tomorrow how I make out.
(if there is no up date I may be stuck under the car) lol
Also will the rear tires need to be aligined after this? If so I may change the other rear bearing as it has 192,000 on it. Although the right one sounds and feels fine.
Unread 04-13-2007, 07:34 AM   #11
jonni325
Bearing was bad 1 side of the double race was bad, When I pressed it out it fell apart, It is quite a DIY project but in total about 6 hours, taking time to mark and properly torque everything. What a difference in noise it is so quite the only thing I hear is the purr og the engine. Thanks again for all the helpful suggestions, I checked out all the items while under the car, and it looks good.
Again Thank you
John
rear noise, E30, mzbmw325i E21, E30 20 04-07-2010 10:12 AM
E30 Stock Headunit/Stereo to Aftermarket kalmoth Car Audio and Electronics 5 09-25-2007 03:35 PM
slight knocking sound to rear wheel area saltcoats E46 7 05-25-2006 02:43 PM
