Unread 03-20-2007, 05:35 PM   #1
Service engine soon light
So for about 9 months now the 330's service engine light sooon has been on.
OF course my parents didnt do anything about it.
had the codes read today.
P0369-Camshaft position sensor
p050 Idle control system malfunction
p0128 coolant temp below thermostat
P0313 Misfire
so i was told that Coolant temp below thermostat is a regular bmw fault, not a big deal.
as for misfire it could have been due to lack of fuel while driving on empty.
but the other two..idk.
The light is turned off now, how long before it would come back on if there was problems with the idle control or crankshaft sensor?
after i had the lights reset i drove the car, took it above 5k almost to redline, figuring that might set off the sensor errors again. nothing
so..ideas?
btw the car seems to run better after the lights were reset.
Unread 03-20-2007, 07:06 PM   #2
metalmukisha
metalmukisha's Avatar
Your Ride: E46 325ci 2004
that always happens so dont get happy to early the light will come on again in a couple of days.....
Unread 03-20-2007, 10:16 PM   #3
meaning...?
if its the same codes. i would assume i have to fix something?
Unread 03-21-2007, 05:41 AM   #4
If the CPS was shot, then I doubt the car would start. So it 's probably the wiring harness, maybe an intermittent issue. Check to see if it's making good contact, any fraying, etc...
Unread 03-21-2007, 08:23 AM   #5
Drive the piss out of it for a few days, if you get lights and or break it then get it fixed.
Unread 03-21-2007, 10:54 AM   #6
drz
Title: local dumbass
Rate My Car: 34 / 340
Your Ride: E36 2.8i
I don't know if camshaft position sensors go bad progressively, or if they are either good or bad. That would be the first thing to look at. Check the wiring or even have it replaced. I can see more than one code going away after you resolve the CPS issue.
Unread 03-21-2007, 11:54 AM   #7
metalmukisha
go to the dealer!!! remember its a bimmer you have to take care of that sweet ride!!
Unread 03-21-2007, 01:06 PM   #8
drz
Your Ride: E36 2.8i
^^ That's not an uncommon stance to take in other countries, especially ones in which labor is not very expensive. However, at around $80 to $90 an hour for dealership labor (which they inflate the actual labor figures -- why would it take 30 minutes to change a light bulb!?), we preach that going to the stealer should be considered the last resort.
Unread 03-21-2007, 01:08 PM   #9
drz
Your Ride: E36 2.8i
Yo Numark: http://forum.e46fanatics.com/showthread.php?p=4531699
And also: http://www.pelicanparts.com/cgi-bin/...-7-518-628-M36
And for metalmukisha to get a picture, the sensor is $108 shipped. The job is a simple task. This is what someone posted on E46fanatics:
Originally Posted by murph1379
yikes, I paid like $350 to have this done by the dealer! Wish I'd known what was wrong!
Numark, I would still first check the wires and connections. Sometimes, however, $100 is worth the peace of mind in my opinion.
Unread 03-21-2007, 01:29 PM   #10
heh i was on that site last night.
decided on changing the sensor if i get the error again.
no way am i taking the car to the dealership...way too much money.
I know a bmw mechanic so if i really need it ill take it to him.
Unread 03-21-2007, 01:35 PM   #11
btw ur sig is fucking huge.
k thnx,
Oil Service light? Alpine328i E36 13 03-05-2007 01:20 PM
Service Engine Soon light reset luispest 7 Series (E23, E32, E38, E65, E66) 4 06-28-2006 09:05 AM
