Unread 03-18-2007, 02:33 PM   #1
slinky
Your Ride: 2000 Z3
Brake Fluid/stabilty
Hello
I'm new and not technical at all. My 2000 z3 2.3 w/41000 has a brake fluid light light on and I think the stabilty light . When I checked the fluid level it was good. I did notice the wiring harness attached to the resivor seems like it dry rotted and snapped from where ever it leds to. Is this common? or is it something I did, but I never touched it before. Thanks.
Chris NJ
Unread 03-18-2007, 03:20 PM   #2
It sounds like the sensor/harness is dead and you probably need to replace it, as long as you actually have enough fluid you will be alright. I'm not sure what stability light you refer to, the DSC light would be an orange triangle with a circle around it or a circular arrow.
Quality Brake Package (rotors, pads, lines) Spieluhr Vendor/Dealer Comments & Supporting Vendor Announcements 2 08-28-2005 02:05 PM
