Unread 03-15-2007, 08:31 PM   #1
snumfalzumpa
Your Ride: 1996 BMW 328i
Car Won't Start
I have a 1996 BMW 328i, and my car won't start. I had just started it, then I forgot something in my house so I turned it off, when I came back to start it, it said 'brake light circuit', and it won't start. It's in park, but when i try to start it, the same thing happens as if you were trying to start the car in Drive or Reverse, nothing happens. Any Ideas?
Unread 03-15-2007, 08:38 PM   #2
If that happens to me I'd try turning the key on, putting the shifter in drive and back in park (guessing)
Unread 03-15-2007, 10:12 PM   #3
QcMarque
QcMarque's Avatar
Your Ride: 1994 740i
On my car the ignition cylinder just crapped out... the acc. and run position work fine still, but the crank position quit. So I had to install a start button (last resort usually) - will your car still not crank?
Canadian by blood... German by ride
Unread 03-15-2007, 10:17 PM   #4
Sounds like it's nuetral safety switch. As previously stated run it through the gears and place it in park or nuetral and try turning it on.
Unread 03-19-2007, 12:51 AM   #5
snumfalzumpa
Yeah I tried doing all of that, and none of it seemed to work, the car still won't turn over or anything. Any more ideas?
Unread 03-19-2007, 11:56 AM   #6
try jumping it? or put a voltmeter on the battery at least?
Unread 03-19-2007, 01:29 PM   #7
loudnfast
loudnfast's Avatar
Rate My Car: 267 / 340
Your Ride: 89 325 e30,90 535i e34
Send a message via MSN to loudnfast
Im having the same problem this morning on my 535i 1990 .batterys good , but its not starting ,lights are bright ,central locking good, but my windows wont work and i get nothing when i crank it...was fine at 2am lastnight .any one have any ideas?
Unread 03-19-2007, 04:40 PM   #8
Starter crapped out, or some connection to it...?
Unread 03-19-2007, 10:20 PM   #9
QcMarque
QcMarque's Avatar
Check your relays, fuses, and the ignition(key) cylinder itself, if those are good check the starter... otherwise I'm not sure. Fuseable link somewhere maybe.
As for the windows... does your car have a master window switch to cut the power to them (mine does... which I thought was odd). If so check that to see if you can operate them.
Unread 03-23-2007, 12:51 AM   #10
snumfalzumpa
Well I'm thinking it might be the starter, but before this happened it was perfect, everytime i started my car before this it would start up in about 1 second.
Unread 03-23-2007, 04:02 AM   #11
Get a voltmeter and connect to your battery - if you have 11 volts or less your battery needs to be charged or replaced. Lights, central locks, etc take minimal amps to operate, whereas your starter draws almost 200 amps to crank motor. Another thing to check is cables on starter - they corode easily because they're exposed to moisture, grease, dirt etc... wire brush cable ends - ALL of them and at both ends
Re: "Snums" - it too could be a dead battery - try the above & charging battery - also you might have a flat spot in starter - I'm betting it's a combination of dirty/coroded cable ends & a weak battery
Unread 05-22-2010, 07:38 PM   #12
MyXc351
Your Ride: 1989 525I
Hi guys, my 89 model 525i does not start on regular basis.... usually gets going again after putting battery on charger for a few hours.... also when this happens... my dash loses most of its functions till battery is charged up again then its good for a few more weeks I suspect i got a short somewhere or a crook alternator. Will get it checked out one day
Unread 08-27-2010, 01:10 AM   #13
neilferril
Title: Read Only Club
Your Ride: '92
Thumbs up hi Myx
Have you checked the battery of your car? maybe you just need to purchase a new car battery since the rate of the discharge is rather fast. Aside from it, you should also check the wirings of your car, specially those which are in the dashboard. It will be very hard to have a malfunctioning dashboard because your safety will be at stake here.
24 01-22-2008 05:54 PM
Car Will Not Start vIcKtOr9 E36 1 01-25-2007 08:54 PM
Car not switching on, self works but doesnt start the car, plz help guy... djfactor E12, E28, E34, E39, E60 3 11-09-2006 07:08 PM
MAJOR PROBLEM - Starting Car!!!! HELP!!! projal147 E36 12 09-07-2006 11:18 AM
Car wouldn't start??? EnvyM3 E46 6 01-05-2006 05:45 PM
