Unread 03-13-2007, 02:02 AM   #1
chhigo
Your Ride: bmw 316i e30 1989
Exclamation Vibration when release the accelarator padel
Dear Friend
I have a BMW E30,316i 1989 M40 engine car. When release the accelarator, engine RPM going to 650-700 and badly vibrates the car. After vibrates, engine going back to normal RPM(800-850) and runs smoothly. This is happening alway when release the accelerator padel. This problem bit verse when A/Condition is on. Please give me some tips/solution to resolve this matter.
Best Regards
Channa
Unread 03-13-2007, 07:51 PM   #2
Exilion
Exilion's Avatar
Your Ride: 1991 325i
Well I'm not an expert but since no one else has responded I figured I'd at least give the thread a bump.
It can be almost anything from the fuel and air filters, to bad spark plugs, or valves needing adjustment. Check what maintenance has been done recently. I personally don't have any experience with the 316i so I don't know any of it's quirks. Also is the engine rpm dropping past normal rpm down to 650-700? And does it only vibrate when it reaches 650 or does it vibrate all the way back to normal rpm?
Also I believe your bmw has an onboard diagnostic system that you can use. This link should explain it for you. http://www.pelicanparts.com/BMW/tech...nostics%20.htm.
This might help narrow it down.
Unread 03-13-2007, 11:35 PM   #3
not sure, but you may want to check the vacuum lines.
also fuel filter as stated above. I know my M42 needs 91 octane, make sure you are running premium gas, i know mine vibrates and knocks with crappy gas.
also check your O2 sensor.
Vibration 45-65 MPH DropTopM M3 16 03-28-2011 02:51 PM
Wierd vibration at high speeds projal147 E36 24 07-24-2010 02:43 PM
How Do You Release Timing Chain Tensioner ?? singring E36 3 05-29-2006 03:15 PM
AMA press release c1apton Comedy Collection
0 10-12-2005 07:01 AM
