Unread 03-12-2007, 10:34 AM   #1
Mack033
Steering Controls Help Needed
I have an 01 I am reconditioning, 1st BMW so I am not familiar with the vehicle, My volume controls and cruise do not work, but the switch to activate the cruise does come on the consul, any thoughts?
Unread 03-14-2007, 06:16 AM   #2
Mack033
Correction, Checked fuses all ok, the cruise control now works, all controls on the other side not working no illumination on any of the controls.
..With 14 views and no responses, this appears not to be a common problem...I will take it to a dealer
Unread 04-05-2007, 08:56 PM   #3
Mack033
In case someone else has this problem I found the information on another site
Jerry, I mainly see a faulty Slip ring coil assembly causing this. Also usually see airbag light on too. The slip ring is the component that connects the rotating buttons with the stationary column. You must take airbag off. Advisable to do so with the battery disconnected and key off. Let me know if you need further instruction.
-Evan
Steering Rack Q. Numark318i E21, E30 12 02-20-2007 12:56 AM
Sony PS3 to Feature Parental Controls komodo United Off Topic  **FOR MEMBERS ONLY** 7 11-28-2005 05:37 PM
Power steering. catalyst E36 4 07-26-2005 12:04 AM
steering wheel cruzin 323is E36 17 04-26-2005 06:18 PM
