Unread 03-05-2007, 11:17 AM   #1
dinan540
dinan540's Avatar
E39 Baller Radiator
I just purchased this all aluminum radiator, shroud, electric fan, resorvoir and 2 speed fan switch for my E39.
http://www.zionsvilleautosport.com/s...ry_Code=CCSE39
540i with some mods
Unread 03-07-2007, 01:57 PM   #2
dinan540
dinan540's Avatar
No love for the zionsville
540i with some mods
Unread 03-07-2007, 02:08 PM   #3
drz
Title: local dumbass
Rate My Car: 34 / 340
Your Ride: E36 2.8i
I have been hearing all kinds of bad things about them lately. Sorry for the you
Unread 03-07-2007, 03:04 PM   #4
myndgone
myndgone's Avatar
Your Ride: E39 540
just curious, what kind of bad things?
Unread 03-07-2007, 03:13 PM   #5
drz
Your Ride: E36 2.8i
Bad costumer service, long waits for product arrival, and one guy ordered some stuff that came in all rusty-looking.
Unread 10-18-2008, 03:21 PM   #6
kingfish
Your Ride: 2001 BMW 525i
I have a 100k miles on my 2001 525i bimmer. Should I change the Fuel Filter? Is so where is it on the car? Also I need to replace my Alternator. If I let my car sit for a few days the battery looses it's charge. This morning when I went out to start my car it was DEAD. I checked the voltage with my meter and it indicated 5.9 volts. Another thing when the voltage drops my remote doesn't open the doors if I fiddle around with the remote long enough the alarm goes off. My car runs rough when I first start it up after charging the battery. It will run ok for a while and then it starts dieing at stop lights. This is why I'm changing the alternator. But I was told that I should change the battery also especially if it is not holding a charge. The Green, Yellow, Black indicator is BLACK. Can you recomend a good Battery other than dealer? Should I be looking at O2 sensors also? I have replaced the radiator and water pump but I noticed today when I removed the alternator that the upper radiator hose is leaking. This explains the whinning noise I get when I first start the car. Some one told me the fan is blowing the radiator fluid onto the belts. Makes since to me. I also found a leak under the power steering unit which contributed to the alternator problem. If anyone wants to jump in here and give me some advise I surely would appreciate it.
Unread 01-06-2009, 08:50 AM   #7
Shy Shy
Your Ride: 2000 E39 Sports
you're not alone.....i'm a victim of the upper rad hose leakage and i also have a whining noise on my 528i, gona change the hose today....already changed the rad.....
Radiator neck broke Dudesky E36 0 05-08-2006 04:14 PM
E39 T-Shirts, Yes/No ? nightdevils United Off Topic  **FOR MEMBERS ONLY** 15 04-10-2006 10:22 AM
E39 M5 brakes dinan540 E12, E28, E34, E39, E60 5 03-27-2006 11:18 AM
DIY: E36 Saggy or Loose Radiator Fix. Cheap & Easy. delmarco BMW OEM Parts Department DIY's & FAQ's 0 11-09-2005 12:36 PM
