Unread 02-27-2007, 01:26 PM   #1
Alpine328i
Your Ride: Alpine White 1996 328i
Send a message via AIM to Alpine328i
Oil Service light?
You know on the E36 (well, the 1996 model anyways) there's a series of lights in the dash for maintenance? It's like 5 greens, 1 yellow and one red? Well, mine's yellow and it says, "Oil Service" or something like that.
Does this mean the car's telling me I need an oil change? Or is "Oil Service" something more complex like an ACTUAL SERVICE that's required? I just had an oil change like 1,000 miles ago...
Also, if it's an ACTUAL SERVICE that needs to be done, can anyone tell me what it includes? Thanks!
Weird....
Help?
---Bailey
"In the road of life there are Bimmers and there are Bimmers"
Mods: Full JDM lighting, APC bulbs, ///M rims, Four wheel Brembo rotors, Bilstein Touring suspension.
Unread 02-27-2007, 02:20 PM   #2
AFAIK it means an oil change at least
AFAIK = as far as I know
Unread 02-27-2007, 03:39 PM   #3
Alpine328i
AFAIK? Am I missing something...
And I called a BMW dealership and they said they cant tell unless they see it first... WTF?!?!?!?!?!
---Bailey
Unread 02-28-2007, 02:48 PM   #4
cainchapman
cainchapman's Avatar
Rate My Car: 127 / 340
Your Ride: 1995 540LE
An oil service indication means exactly that. You have not done enough km's in a year for it to need a service, but it still requires and annual oil (and generally Brake) fluid change.
It doesn't require and Inspection I or II
Unread 03-01-2007, 05:21 AM   #5
akinthecat
Your Ride: 1999 320i
have an oil change asap, using quality oil (i'm using castrol which bmw recommends) and an original filter. Remember to reset the meter again. My shop takes a look at my belts and checks out all other electricals and fluids and does remind me to bring her in for the next repair.
Unread 03-01-2007, 09:32 AM   #6
elsabor67
elsabor67's Avatar
Rate My Car: 35 / 340
Originally Posted by akinthecat
have an oil change asap, using quality oil (i'm using castrol which bmw recommends) and an original filter. Remember to reset the meter again. .
My 2 cents to you is not to use Castrol. I used to be a castrol fan and then switched because it was breaking down so quickly(specially because of the way I drive, WIDE OPEN ). BMW and other mechanics that I know here in Germany recommended for my E30 Mobil-1 10W40 synthetic and it doesn't become drinking water by the time my oil change is due around every 4 mos or 3000 miles. On the light you can reset that yourself if you want. I reset mine every time I do the oil change and when I tune it up.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Unread 03-02-2007, 12:35 AM   #7
robertplattbell
Your Ride: 1997 328iC
You need to buy a code reader and reset tool. Not only will it reset the check engine light and read error codes, it resets oil service indicators lights and inspection lights. Get a Bently Manual while you are at it. It sounds like someone did not reset the lights at your last oil change, if it was only 1,000 miles ago - did you do your own oil change? (or do you only drive 1000 miles a year?)
This is a 11 year old car. You can't be calling the dealer every time a dashboard light goes off. Get the code reader and manual, and find a good independent BMW mechanic. Dealers are for fixing fiddly warranty repairs on new cars. The Bently manual will tell you what preventative maintenance you need to do on these cars (brake flushes, radiator flushes, etc.) as part of the "Inspection I" and "Inspection II" protocols.
BMW Brand Motor oil from the dealer is Castrol Synthetic, and it is what BMW recommends (newer BMWs have this written right on the oil cap, or at least my E53 does). Any good quality synthetic (Castrol, Mobil-1, Volll Synthase) should work well in these cars. I change annually, about every 5-7K miles with Voll Synthase 5W40. Supposedly, you can go as long as 15,000 miles on a good synthetic, but I plan on keeping my cars.
Good Luck.
Unread 03-03-2007, 12:43 AM   #8
215BIMMER535
215BIMMER535's Avatar
Rate My Car: 123 / 340
Your Ride: '97 328i
ground i think pin 17 for exactly 3 seconds, and exactly 11 seconds with the key on and engine off. this should reset all the lights, and i see the same lights whenever i wait too long before an oil change. when you had yours changed did you have the lights reset?
Unread 03-03-2007, 03:18 AM   #9
elsabor67
elsabor67's Avatar
You're close, it's pin 7 and 18 or seven to ground for 3-6 seconds to get all 5 green and anything past that resets your inspection lights that are there too. I do recommend that the cable you use be fused(a fuse between both ends) and have a second hand there. This link (http://www.noren.com/bmw/e30reset.htm) gives you detailed instructions and has helped me maintain my changes with no problems instead of having to find someone here with the tool to charge me to set the lights again.
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Unread 03-03-2007, 11:31 AM   #10
Boxer19
Boxer19's Avatar
Your Ride: 2001 525i
Good Luck.
Where can I get Voll Synthase? Is is available in the US?
Ever stop to think and forget to start again
Unread 03-03-2007, 01:25 PM   #11
215BIMMER535
Your Ride: '97 328i
yea i dont remember the pin number i just know where it is when i go to do it. that and i've never had an service light problems after resetting the meter. btw it's hardly a 2 person job
Unread 03-04-2007, 10:13 PM   #12
akinthecat
215bimmer, my car looks similar to yours cept the wheels and a rear spoiler
Unread 03-04-2007, 11:26 PM   #13
scrichy84
Your Ride: 1995 325i (Sold), 2004 Tacoma (Sold), 2006 Jetta TDI, 2007 Rabbit
I just did my own oil changes and took the light out! It worked great!!!
The lights just go off of milage. In the 1996, I don't think there is a viscosity sensor for the oil.
Scrichy84: 1995 325i sold, 2004 Tacoma sold, 2006 TDi Jetta, 2007 Rabbit
Unread 03-05-2007, 01:20 PM   #14
Alpine328i
I'm not buying anything for it.. I'm trying to sell this POS money pit anyways, but in the meatime, the beeping is quite annoying.
I go to Valvoline Instant Oil and they dont have a reset tool (I called them and confirmed that) so that's probably all it is.
Thanks to all who replied.
---Bailey
Yellow "Low Oil" Light doughboyea E46 19 04-06-2011 06:45 PM
E34 Service Indicator Light Reset e39 bimmer E12, E28, E34, E39, E60 0 01-01-2007 12:17 AM
Service Engine Soon light reset luispest 7 Series (E23, E32, E38, E65, E66) 4 06-28-2006 09:05 AM
