Go Back   United Bimmer Community - BMW Forum > UnitedBimmer-General BMW Topics > Forced Induction
Forced Induction Sponsored by: SmartAutoWarranty.com
Discuss Forced Induction on BMWs with SmartAutoWarranty.com (turbos and superchargers).
Unread 02-28-2007, 11:33 PM   #16
dinan540
dinan540's Avatar
Thanks Matimus. I have some E39 M5 headers which are essentially the same as the e39 540 headers and I want to use them and mod them to make them flow better. I have never done it and I don't know if it is worth my time to try. Basically the V8 headers made by supersprint are several thousand and the dinan headers are even more than that. I don't want to spend the money on them at this time.
Thanks for the price breakdown. Did you have to ship your head and block or was it a local place?
Paul
540i with some mods
Unread 03-01-2007, 05:05 PM   #17
Originally Posted by matimus
why is that (currious) oil pres. and temp on the A pilar, with the Boost controller, Wideband 02 and water temp by the ashtray works best for me.
I didn't realize you had more down there, i have never been a big fan of gauges on the a-pilar, and I don't like the white gauges for the spedo/tach, thats all. Other than that it looks sweet.
Unread 03-18-2007, 09:16 AM   #18
matimus
matimus's Avatar
Your Ride: E30/S50 GT35R+ E30M3
Heres some misc parts, B&M oil cooler with -8 lines and fittings, Aeromotive A1000-6 Fuel pressure regulator, silver Vacume lines( gotta stick with the theme), HKS SSQ BOV, -6 SS fuel lines and fittings.
Here i got the UUC moderate wieght Steel flywheel mounted with the modified M5 pressure plate and Ultra-smooth cerametallic clutch disc, good for 650 wtrq.
heres a pic of the solid tranny bushings eith the enforcers on them. This tranny/ engine aint moving anywhere!!!!
While i was doing the engine build i decided to get rid of the crappy suspension that this thing had before, so i got all new bushings, control arms that include new ball joints, new steering arms, bilistien sport shocks all around, new "offset" upperstrut bearings (to correct the camber a bit).
Its the boring part of this build so i only took one pic of it.
here it is:
hope you guys like it so far.
more to come tommorrow when i get the engine in.
Unread 03-18-2007, 09:20 AM   #19
matimus
matimus's Avatar
ok, ive been woring pretty hard this weekend
heres some updates, I got the engine in yesterday and started hookin stuff up.
Heres the engine on its way in
Engines half way in. Man its a litle tough doing this by yourself. but it went smoothly.
There we go, got it in there, now to start hooking things up
i got the spark plugs in and the coils in. Notice my sweet custom manifold, made by yours truly
here i got some of the covers on and some of the wiring
Heres a nice front view showing the intercooler, aluminum rad, next is to mount the high output dual fans.
Today i'll start wiring the boost controller, gauges, NGK AFX, and some other misc. things.
This week my driveshaft should be finished being built. some i can throw that on, then its off to AFI for the intercooler pipes and 3.5" SS exhuast.
Unread 03-18-2007, 09:24 AM   #20
That's just so impressive You just built a show winner!
Unread 03-18-2007, 12:57 PM   #21
that is going to be an amazing car! It is cool to see the pics also
I hope you will post some vids once you fire her up!
Unread 03-21-2007, 03:24 AM   #22
B_w.
Rate My Car: 62 / 340
Your Ride: turbo e36
haha, i cant believe i didnt see this thread till now lol. keep up the good work buddy!
i think edmonton is going to be the FI capital of UB when we are done
Unread 04-01-2007, 11:52 AM   #23
matimus
matimus's Avatar
yeah edmonton FTW
well heres a little update.
good stuff first.
vibrant exhuast 3"in and dual 2.75" out, stainless steel turbo coolant and oil feed lines with stainless fittings $$$$$, Ross machine racing billet fuel rail and fittings.
Heres a pic of the exhuast, See through ,
shouldnt be much restriction here.
Heres some more stuff,
high flow fuel filter, 3" exhuast flex coupler, adjustable short shifter, and the sweet adjustable dual fan controller and wiring from diftech.com.
Now heres the shitty part,
i was installing the OEM fuel rail with the stock fuel injectors that i was going to use for the break in process and while installing the injectors the plastic tip was so brittle that it broke off into the intake manifold.
Unfortunately it fell into the port where the valves were open so into the cylinders they went.
they set up shop right on top of my pistons . I tried everything to get the pieces out but since plastic is not magnetic it was very hard. needless to say, i had to remove the entire cylinder head to retrieve the pieces.
heres a pic of the crappy OEM injectors.
notice the two broken ones on the right compared to the normal one on the left.
anyways, i got it all back together in a couple of hours but im not sure what to do know. i might get a tune for the new injectors with no boost for the breakin.
driveshaft wasnt done for this weekend so i guess i will have to wait to start it up untill next weekend.
thanks,
///MAT
Unread 04-01-2007, 04:32 PM   #24
B_w.
ouch, that sucks...dont worry, i am going fishing for a spark plug tip right away
i have my stock injectors if you need em...think they should be the same
Unread 07-25-2007, 08:39 PM   #25
TechniqueTuning
Title: UB Supporting Vendor
Your Ride: 2001 BMW 330ci Turbo, 2002 X5 3.0
Nice looking manifold. Looks like the setup has a lot of potential.
Nick Glantzis
Technique Tuning Inc.
BMW Turbo Systems and Forced Induction Tuning
Unread 07-25-2007, 11:55 PM   #26
B_w.
hope you get that beast up and running soon bud. hopefully that autronic is all its said to be.
nick, how do you feel the autronic sm4 stacks up against the stock ecu for an application like this?
Unread 07-26-2007, 12:08 AM   #27
bill@bimmerclinic.com
bill@bimmerclinic.com's Avatar
Your Ride: Couple M3's
Nice work! Any updates?
Unread 07-26-2007, 12:27 AM   #28
Kasei
Kasei's Avatar
Your Ride: 1991 525i
Wonderful job, I bet it will be sweet to get behind the wheel and let her loose after doing so much to it.
Unread 07-26-2007, 12:58 AM   #29
scooter
scooter's Avatar
Rate My Car: 296 / 340
Your Ride: 99m3
beautiful dog, i love boxers.
the car's O.K too...
Unread 07-26-2007, 03:28 AM   #30
B_w.
matts out of town so i will answer for him
the car is in the shop getting an autronic sm4 installed and tuned. should be out in a week or two if all goes as planned.
turbo 328 B_w. Forced Induction 138 03-30-2007 02:32 PM
what turbo and fuel upgrades to do? SMS19 Forced Induction 12 03-21-2007 03:17 AM
1998 Lotus Esprit V8 Twin Turbo..... $44,900 LotusofGreenwich Bmw Cars For Sale/Wanted 0 01-16-2007 05:35 PM
Ticco E30 Turbo video voca Video and other Multimedia 6 11-15-2005 04:02 PM
