Go Back   United Bimmer Community - BMW Forum > UnitedBimmer-General BMW Topics > Forced Induction
Forced Induction Sponsored by: SmartAutoWarranty.com
Discuss Forced Induction on BMWs with SmartAutoWarranty.com (turbos and superchargers).
Unread 02-26-2007, 01:46 AM   #1
matimus
matimus's Avatar
Your Ride: E30/S50 GT35R+ E30M3
My E30/S50 Turbo build
I acvtually started 2 months or so ago. but heres the details:
COMPLETE!! rebuild with:
-CP 8.5:1 forged pistons
-Eagle H-beam Rods
-ARP head studs
-MLS.70" head gasket
-ALL! new gaskets, seals, bearings, chains,rails, tensioners,etc,etc
-New VAC oilpump upgrade
-PWR 57mm ALUMINUM RAD
-Gt35r turbo
-UUC stgeel flywheel with M5 ultra smooth cerametalic clutch
-Full 3 angle valve job
-new valves
-port and poilish head
ARGGHH>>>>>>>> way to much to keep listing. i'll post a spread sheet at the end of alll the mods
VFE supercharger removed and ready to remove from chassis
engine out
intercooler almost mounted:
intercooler mounted and engine bay empty
disassembly continues:
and continues some more:
Head is off and inspecion looks good. all is well.
piston #5 was a little ruff, we'll fix that
block completely stripped and off to the machine shop
old pistons , rods, etc.
crank and olod spark plugs:
The secret to the power- GT35R .82A/R:
VAC MLS .70" head gasket and ARP head studs:
CP pistons. 8.5:1 CR
polished parts;
Unread 02-26-2007, 01:47 AM   #2
matimus
matimus's Avatar
UUC stage 2 STEEL flywheel w/M5 ultrasmooth cerametalic clutch,
UUC tranny bushings(red), and UUC tranny enforcer cups, Eagle rods, VPD oil cooler cap, Guage pod
guage pod mounted with oil temp and oil press guages
PWR 57mm aluminum rad, manifold parts, genuine Hamann HM2's
block back from the machine shop. hot tanked, media blasted, bored to 87mm, decked,balenced etc. ready for p[aint;
finished painted, pistons installed.
head back from machine shop, AEM tru-boost and replica tial wastegatein the background.
view of the bottom with eagle rods and balenced rotating assembly:
partly assembled. eagerly awaiting install:
copper sealing sprayed gasket
head installed and all assembled readey to drop in to begin manifold mock-up:
SELF MADE manifold almost done(ran out of pipe) not bad for the first one ive ever made eh?
thats all for now.
Unread 02-26-2007, 02:56 AM   #3
elsabor67
elsabor67's Avatar
Rate My Car: 35 / 340
Looks sweet. How much power are you guestimating at the wheels after all is installed?
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Unread 02-26-2007, 08:08 AM   #4
matimus
matimus's Avatar
i'll be running at 20psi so depending on the efficiency of my manifold it should be 530-550rwhp.
Unread 02-26-2007, 08:44 AM   #5
"killer"project/pics. btw- great DIY (someone actually doing it the correct way not bolting kit onto a tired motor)
Unread 02-26-2007, 10:09 AM   #6
scrichy84
Your Ride: 1995 325i (Sold), 2004 Tacoma (Sold), 2006 Jetta TDI, 2007 Rabbit
Sweet Pics. It looks like you had the patients to do it right and make it look good!!
Scrichy84: 1995 325i sold, 2004 Tacoma sold, 2006 TDi Jetta, 2007 Rabbit
Unread 02-26-2007, 10:48 AM   #7
RSF5
RSF5's Avatar
Rate My Car: 278 / 340
Your Ride: NOOTHHHIIIINNG
Ooooo good looking. That shouldn't be *too* costly of a project considering how much work your doing yourself. And specific problems or pluses you want to share about the manifold? I'm really interested in that.
edit: Sweet dog. What kind is it?
Unread 02-26-2007, 12:10 PM   #8
hawt.
E30..fast as shit ftw.
Unread 02-26-2007, 12:33 PM   #9
dinan540
dinan540's Avatar
How much of the work did you do yourself? Did you send it to machine shop for the port and polish?
What a awesome project. Congrats on the almost completion of the project.
540i with some mods
Unread 02-26-2007, 01:52 PM   #10
RSF5
RSF5's Avatar
This pick give me more than a little bit of a hard on.
edit: *fap*fa- No I won't do it.
Unread 02-26-2007, 09:13 PM   #11
matimus
matimus's Avatar
thanks for your kind words. Everything is new on this engine. ALL seals, bearings, bolts, chains, tensioners, gaskets, o-rings, starter, etc , etc. I didnt want any problems.
I saved alot by doing the disassembly and assembly myself. aswell as the builiding of the manifold myself. but it has still been quite pricey.
The advantages of building you own custom manifold is that you get the turbo to sit exactly where YOU want it. For my application (s50 in an e30) my opotions were very limited in the availability of a manifold. I contacted many people in the custom turbo biz and no one had a manifold for this application. So basically i had no choice.
There are advantages and disadvantages to a bottom mount versus a top mount turbo but. they are minimal.
Top mount-
advantages- easy filter changes, easy servicing, no oil drain issues.
disadvantages- needs a custom manifold($$$$), ads more bends to the IC piping and usually two extra 90's in the exhuast down pipe (self explanitory), places weight up high,
bottom mount-
advantages- out of the way, keep weight down low, relatively straight exhuast, easy IC piping.
disadvantages - possibly oildrain issues, difficult filter changing, difficult servicing.
BTW my dog is a Boxer
thanks,
I did all the teardown myself, then i took the block and head seperatly to the machine shop. where they did all the porting,polishing, boring , balencing , etc.
thanks, thats what its all about.
Do it right the first time. right?
I kinda went a little far though i think. While the engine was at the machine shop i had a couple weeks to tinker in the garage so I polished all the covers to a mirror finish and all the bolt heads ( i know i know.....too far )so everything is shiny and new. Plus i bead blasted the valve cover and re-sprayed it black. mabey a bit excesive but whatever. i had time
I couldnt put dirty parts back on this new engine. I just couldnt.
thanks,
///MAT
Unread 02-28-2007, 01:37 PM   #12
dinan540
dinan540's Avatar
///Mat,
How much did the machine shop charge you to port and polish the block and head?
How did you make the custom manifold? What materials did you use and any sources, books, pictures, etc? Are the headers all of same length?
540i with some mods
Unread 02-28-2007, 05:26 PM   #13
Very Cool project, the only thing I would change are your Dash Dials and move the A Pilar Gaugues into one of the pods that goes in the ash tray.
Unread 02-28-2007, 07:32 PM   #14
2002guy
Your Ride: 1974 2002
lookin good...cant wait to see more... and nice choice of pictures on your wall
Unread 02-28-2007, 10:48 PM   #15
matimus
matimus's Avatar
///Mat,
All the machine work,
install cams----------------------------------donated
Cylinder bore x 6 --------------------------$168
Crank polish--------------------------------$63
3 angle Valve grind------------------------$431
Valve guides R&R--------------------------$156
Clean block---------------------------------$81
Crankshaft balancing---------------------$290
Assemble short block (basic)------------$366
Resurface block to 16rl-------------------$102
Main bearing set---------------------------$209
Rod bearing set----------------------------$89
Cam chain tensioner----------------------$141
Resurface cylinder head to ~16rl-------$60
timing chains-------------------------------$170
port and polish head---------------------$ donated
Total-----------------------------------------$2326
As for the manifold, i ordered all my parts from 666fab.com (aka jon Volk) he is a legent, if you will, on manifold designs and fabrication. 1 of the best for sure. It is made from t304 stainless steel , the flanges are 1/2 thick stainless steel waterjet cut.
It is not equal length though. it utilizes as short as possible individual runners to keep heat loss at a minimum, which helps spool. equal length is not necessary unless it is a full blown drag car. Egual length usually yeilds a later/slower spool while giving more top end hp and flow capabilities. A simple "log style" as in the spa manifold is a great design due to its short runners and thick cast iron construction( keeps heat in) and has been proven to work well for up to around 650whp . The "log" or "tubular" (what mine is) Is better for street applications because of its faster spooling and easy construction. tubulars flow more and can produce higher hp. cast logs will last longer than tubulars. I will also be ceramic coating it inside and out . to keep the heat inside.
Basically, nice easy sweeping bends and short runners will work the best.
I'll gather up some more info i have and pm it too you.
why is that (currious) oil pres. and temp on the A pilar, with the Boost controller, Wideband 02 and water temp by the ashtray works best for me.
My tuner sits in the passenger seat, he only needs to play with the boost controller and Air/fuel guage. hence why they are mounted closest to him.
haha , thanks
turbo 328 B_w. Forced Induction 138 03-30-2007 02:32 PM
what turbo and fuel upgrades to do? SMS19 Forced Induction 12 03-21-2007 03:17 AM
1998 Lotus Esprit V8 Twin Turbo..... $44,900 LotusofGreenwich Bmw Cars For Sale/Wanted 0 01-16-2007 05:35 PM
Ticco E30 Turbo video voca Video and other Multimedia 6 11-15-2005 04:02 PM
