Unread 03-24-2007, 12:25 AM   #16
k so i might be post whoring now?
so everythign is in except the tie rods, I need to finish that sunday or monday due to work tomarow.
So as far as the knuckle goes i did not have to fabricate it at all, first of all it was different from the above DIY, and also my steering collum telescopes, so I just had to push the collum up and haazah it was good.
as far as teh plumbing goes its a very tight fit. I had to wrap the High pressure hose around the actual rack to get it to fit right. But i didnt have to bend any metal to get it to fit.
also in my 1991 all the hoses were atached to the banjo bolt assemblies. meaning i could not change the plumbing to new stuff(its expensive) as they did in the above DIY.
had a little trouble getting the tie rods loose, but nothing some hammering could fix. Same with the Knuckle removal, takes some persistacne..but eventually it came off.
I had to pry the new rack into place, since it was only a 99% fit. Im hoping this wont effect anything, seeing how i got the rack into the same spot the other one was in.
all in all..not to bad. Im gonna hook up the tie rods, do a basic allignment with a tape measure and take it somewhere to get it all checked out and alligned.
Unread 03-25-2007, 11:09 PM   #17
finished.
steering wheel is crooked..but i think its due to my horrible alignment job.
So ill try to fix that tomarow.
otherwise its f**king sweet to drive. very responsive.
Unread 03-25-2007, 11:12 PM   #18
Nice job!
Unread 03-26-2007, 01:32 AM   #19
drz
Title: local dumbass
Rate My Car: 34 / 340
Your Ride: E36 2.8i
tyte
Unread 03-26-2007, 09:50 AM   #20
was going to say when I did things like tierods on my e36 I did it the same amount of turns that the old tierods had, but then again going from a 4 turn lock to a 2.7, yeah..
Seems like a great project! Do you have aftermarket suspension?
Unread 03-26-2007, 10:48 AM   #21
three years ago i swapped out the old springs for new ones. (at the time thought it was a good idea ) since i did that i just got some bilstein touring shocks with the stock springs. so its a little stiffer but not harsh.
Unread 04-12-2007, 06:15 PM   #22
I finally got an alignment today. steering wheel still squeaks a little(rubber bushing in the fire wall is sqeakig due to the raw metal rubbing against it) and the steering seems to be a little stiffer. Its harder to turn the car..but it turns on a dime, doesnt leak and has no play.
now i have to figure out why the wheel is shaking..but i think its due to my worn out subframe bushing? maybe a bearing? i ve had the wheels balanced numerous times..so thats not the problem. oh well.
Unread 04-12-2007, 06:57 PM   #23
If you find out why the wheel is shaking, let me know. Mine shakes about 0.25" back and forth.
Z3 has turned "squirrelly" lanshrk Z Series (Z3, Z4, Z8) 12 07-24-2009 10:54 PM
Steering Rack Q. Numark318i E21, E30 12 02-20-2007 12:56 AM
Z3 2.8 Roadster engine number - help! dale Z Series (Z3, Z4, Z8) 4 08-19-2006 06:07 PM
Z3 Rear Window Trim Storamin Z Series (Z3, Z4, Z8) 3 06-28-2006 08:34 PM
Any meets coming up? Rooz Southeast Region 5 09-02-2005 12:00 PM
