Unread 02-18-2007, 08:52 PM   #1
215BIMMER535
215BIMMER535's Avatar
Rate My Car: 123 / 340
Your Ride: '97 328i
brake sensor light on dash
now as it should, my brake sensor light came on when i needed new brakes, i got new brakes but no new sensor. is there an easy way to reset the light or just eliminate the power to it? also my fog light indicator light is out and has been for quite some time... what is that tied into in the wiring?
Unread 02-18-2007, 11:06 PM   #2
There are sensors at the front left and right rear for the brake pads. You should just be able to get new ones and plug them into the right spot on the pads and then connect it after you remove the old sensor . I usually pay $5 or so for a new one, its a pretty easy and cheap fix, espcailly if you change your own pads.
Unread 02-19-2007, 05:53 AM   #3
Usually your old sensors are NOT reusable if they've been worn into (they're shorted across triggering the light) as far as the fog light indicator - have you tried a bulb???
Unread 02-19-2007, 10:13 AM   #4
215BIMMER535
Your Ride: '97 328i
yea i know how the sensors work i was wondering if they are simple enough that i can just cut somethin to "unshort" it b/c i know when my brakes are bad, id rather not bother wth new sensors every change. and for the fog light no i havent tried a bulb, does the cluster come out easily to change it?
Unread 02-19-2007, 02:38 PM   #5
QcMarque
QcMarque's Avatar
Your Ride: 1994 740i
Yes and no... on my car the cluster is held in w/ 3 screws along the top underside (top of cluster), then you just pull the top forward, slide the botton out, turn the steering wheel left while pulling the cluster out that way (after unhooking the wires - be sure to note placement of individual bulbs and single wires.) Reinstalling it is just the opposite. Takes a little patience and practice, but once you do it a couple times it's actually quite simple.
Canadian by blood... German by ride
Unread 02-19-2007, 04:03 PM   #6
scrichy84
Your Ride: 1995 325i (Sold), 2004 Tacoma (Sold), 2006 Jetta TDI, 2007 Rabbit
When removing the cluster, make sure you have your battery unhooked if you take off the steering wheel. If you turn on your key without an airbag hooked up you will have another light problem. The ABS light.
The cluster can be removed without removing the steering wheel but it is a pain in the ASS!
Scrichy84: 1995 325i sold, 2004 Tacoma sold, 2006 TDi Jetta, 2007 Rabbit
Unread 02-19-2007, 04:40 PM   #7
You could just get a sensor plug it in and then tie it out of the way, I am currently doing that on my left front, because the dealer gave me a sensor that wouldn't fit on my pad.
Unread 02-20-2007, 09:47 AM   #8
215BIMMER535
Your Ride: '97 328i
ok cool thanks fellas, i like the idea about tyin the sensor away so the thing doesnt need to keep getting replaced. my airbag light has been on since i got the car, but i know that could be the result of a lot of different things so i havent looked into it yet
Unread 02-25-2007, 12:16 PM   #9
zody
zody's Avatar
Your Ride: 1993 E36 Sedan 320i
Send a message via Yahoo to zody
cut the wire leading to the brakes in front left and right rear. inside the wire are 2 wires, so stick them together and the problem is solved, you will never see again the brake sensor light.
LE: this is my first post here so i wanna say Hello! to all of you!
Unread 02-25-2007, 01:19 PM   #10
welcome
Unread 02-25-2007, 10:25 PM   #11
215BIMMER535
Your Ride: '97 328i
thanks zody, thats the kind of answer i was lookin for! and welcome!
Unread 02-28-2007, 08:00 PM   #12
CJH
Your Ride: 1996 328is
Why disable a useful, safety related system for the sake of a few dollars? Why not remove that pesky ABS system & take the air bag out & toss it?
Fix it right, these are highly engineered vehicles, pay it respect & fix it. Plenty of idiots now own these cars, chrome wheels, subwoofers, and endless clear/smoke/LED/angel eye light masturbation.
Unread 02-28-2007, 09:01 PM   #13
Just for clarification, if you don't want to replace the sensors, don't wait till they go off to get new pads It's as simple as inspecting your brake pads and replacing them before they wear down enough the trigger the sensor. The minimum specified thickness for an E36 is 5/64". Thus you should replace them before that- keeping them to about 1/8" or thicker would be a good rule of thumb.
Unread 03-01-2007, 05:25 AM   #14
akinthecat
Your Ride: 1999 320i
Sometime my brake sensors light up esp when it rains heavily and when i drive througha puddle. But it shuts off automatically. I've checked these sensors and my wheel rotors don't seem to have the same thickness in the fronts. the left front is 2.5mm+- thinner than the other. The car brakes in a straight line though...
Quality Brake Package (rotors, pads, lines) Spieluhr Vendor/Dealer Comments & Supporting Vendor Announcements 2 08-28-2005 02:05 PM
