Unread 01-17-2007, 11:05 AM   #1
pottie
Your Ride: 2000 323i
Coolant light
Hello there
I have this little annoying light keep came up once a while
it s a coolant light and I just service and change their radiator hose also some sensor down there and now appear that on the cold days the light is on again...but all temperature is okiee meant in normal condition...is there anyone have similar problems....
And one more thing is there anyone know what kind of Power Steering fluid need to be use in 2000 323i sedan....
Your help and time are appriciated...thanks.......
Unread 01-17-2007, 03:03 PM   #2
jms
jms's Avatar
Title: ______
Rate My Car: 105 / 340
Your Ride: 99 328I Convertible
Send a message via AIM to jms
with the engine cold, check the coolant level, you are probably down a little since you changed the hose. just be careful if you run it low on coolant you can crack the head and the temp sensor will never indicate a problem.
Unread 01-18-2007, 10:20 AM   #3
pottie
thanks mate i ll keep that in mind
Unread 01-18-2007, 11:48 AM   #4
Did you bleed the system after changing hose? That's easily overlooked
Unread 01-18-2007, 12:22 PM   #5
yeah, you might have some air trapped in the system that would cause it to throw a light from time to time...
Unread 01-18-2007, 04:27 PM   #6
jms
jms's Avatar
Title: ______
plus if it hasn't been done in a couple years I would consider a flush just to keep it running nice. I don't know about the e46 but the e36 you need to change the radiator after about 5-6 years because the plastic becomes brittle and it breaks down with disastrous results.
Unread 01-19-2007, 10:35 AM   #7
pottie
Guys thank you so much
I ll keep that in mind specially I ll be doing service for oil change pretty soon so I ll go ahead flush the whole things and replace with new fluid...
btw anyone of you familiar with what type of fluid for power steering cz I have read it in the cap and said ATF fluid only so want to make sure that the transmission fluid with dexron work for that
Again thank s for u re time and help
Unread 01-19-2007, 02:09 PM   #8
Coolant should be flushed every other year and your PS fluid is Dexron atf (you can use about any of the dexrons available - latest is dexronIII but you can use the earlier versions - they're a little cheaper but make sure it says DEXRON)
Unread 01-19-2007, 03:34 PM   #9
pottie
Thank you for the confirmation buddy...i m glad I did used dexron to top off last time...This is a new project for me to learn and maintain cz is my wife who drive it...anyway thank s again and I ll definetly will flush those radiator fluid by the time i change the oil as well..
Unread 01-19-2007, 06:38 PM   #10
also when adding PS fluid - after topping it off slowly turn steering wheel from left stop to right stop and back to left stop - barely touching the stops and just for a couple of secs each - this bleeds air from the system.
Yellow "Low Oil" Light doughboyea E46 19 04-06-2011 06:45 PM
Coolant Leak, Fuck (long post) bartb E12, E28, E34, E39, E60 0 03-22-2008 12:25 AM
Coolant bleed problem - 1997 540i zole2112 E12, E28, E34, E39, E60 7 10-23-2006 06:55 AM
fog light problem HELP! Tochenzo Lighting 6 10-10-2006 11:32 PM
How many forum members does it take to change a lightbulb? bmwcrazy Comedy Collection
6 11-20-2005 09:31 PM
