Go Back   United Bimmer Community - BMW Forum > UnitedBimmer- Model Categories > Other Makes And Models
Other Makes And Models discussion of all other makes and models
Old 01-12-2006, 10:30 PM   #1
bmwcrazy
Audi S6
General Information
Price: $--,---
Miles Per Gallon: --/-- mpg
Curb Weight: 4210 lbs
Layout: Front-Engine/AWD
Transmission: 6-Speed Tiptronic
Engine
Type: V10
Displacement: 5204 cc
Horsepower: 420 bhp @ 6800 rpm
Torque: 397 lb-ft @ 3000-4000 rpm
Redline: ---- rpm
Performance
0-60 mph: 5.1 sec
0-100 mph: --.- sec
Quarter Mile: --.- sec @ --- mph
Skidpad: .--g
Top Speed: 155 mph (limited)
Braking, 60-0 mph: --- ft
Slalom Speed: --.- mph
Source: Audi
Engine Newly developed V10 with FSI technology and ample torque characteristic
Ten-cylinder gasoline engines have long been regarded as a particularly sporty type of power unit. In the form of a V-engine they are short, compact and correspondingly light. The number of moving parts required for ten cylinders is moreover relatively low, bringing the added bonus of low friction losses. It is no coincidence that the Gallardo super sports car built by Lamborghini . an Audi subsidiary . is driven by a widely acclaimed V10 engine.
The V10 in the new Audi S6 is a completely new engine which first appeared in the Audi S8 and has now been specifically retuned for use in the top model of Audi's luxury class.
Its ten cylinders are divided into two cylinder banks arranged at an angle of 90 degrees to each other, and each with two overhead camshafts (DOHC principle); the spacing between cylinder centers is 90 millimeters . one of the reasons why this 220-kilogram (approx. 485 lbs.), four-valve per cylinder engine is so compact. A special intermediate frame reinforces the cast aluminum crankcase.
The bore is 84.5 millimeters and the stroke 92.8 millimeters, producing a swept volume of 5,204 cc. With its crankpin offset of 18 degrees, the V10 fires at an ideal spacing of 72 degrees crankshaft angle. A balancing shaft located between the cylinder banks eliminates the free inertial forces of the first degree and contributes equally towards the engine's notable refinement.
All four camshafts are adjusted continuously through 40 degrees crankshaft angle depending on load and engine speed, thus optimizing filling of the combustion chambers and consequently enhancing the power output. The camshafts are driven by no-maintenance chains and actuate the total of 40 valves via roller cam followers. The task of engine management is handled by two separate control units.
The V10 in the new Audi S6 uses FSI gasoline direct injection. This permits a high compression ratio of up to 12.5:1 and therefore a highly efficient combustion process. The injection system delivers the fuel directly into the combustion chambers in precisely metered amounts, at a pressure of up to 100 bar.
The two-stage magnesium variable intake manifold incorporates electronically controlled tumble flaps; these induce a swirling movement in the air drawn in.
Innovative FSI technology has impressively demonstrated its potential in motor sport . the R8 racing car equipped with it participated five times in the 24 Hours of Le Mans for Audi, winning the race on four of those occasions.
The powerful ten-cylinder engine is designed not simply with power in mind, but to an even greater extent for impressive torque. It achieves 420 bhp at 6,800 rpm, but delivers the peak torque of 540 Nm (approx. 397 ft.-lbs.) at engine speeds ranging from 3,000 to 4,000 rpm. Over 500 Nm of torque (approx. 368 ft.-lbs.) is on tap between 2,500 and 5,500 rpm. The engine exhibits spontaneous throttle response and very refined running, and under load it also produces sonorous acoustics, as befits this dynamic car.
The engine gives the Audi S6 the road performance of a high-caliber GT-class car. The Audi S6 is capable of racing from 0 to 60 mph in 5.1 seconds. The speed is not governed electronically until the needle reaches 155 mph.
The S6 weighs 1,910 kilograms (approx. 4,210 lbs.), including the dynamic, sure-footed quattro permanent four-wheel drive. Every horsepower consequently has to propel just 4.55 kilograms (approx. 10 lbs.) . the power-to-weight ratio of a top-notch sports car.
Drivetrain
More direct for even greater dynamism
The entire drivetrain of the Audi S6 has been designed from scratch. The engine's power on the S6 is translated into motion by a six-speed Tiptronic as standard, which adapts to the driver's style by means of an intelligent feature. The software program that controls this automatic transmission electronically has been optimized to deliver more dynamic gear changes compared with other Audi models; the gear changes are noticeably swifter.
The driver can call up the transmission's "S" sport mode via the selector lever . it will perform upshifts even at relatively high engine speeds. And it is possible to change gears manually in both modes by means of the aluminum-look shift paddles mounted to the steering wheel. The selector lever has an aluminum look and . like the steering wheel . is trimmed in smooth leather.
The Servotronic steering with its variable ratio has a more direct response than in the A6. This, too, results in even more agile handling.
Power and control
Typically for an Audi, the new Audi S6 likewise takes quattro permanent four-wheel drive as its basis. Its virtues are already widely acknowledged: superior traction in all driving conditions. More than a quarter of a century of expertise acquired in this domain by the Ingolstadt-based brand has led to the development of a new quattro generation with asymmetric/dynamic torque split . further evidence of Audi's guiding principle of "Vorsprung durch Technik".
A center differential, installed longitudinally in the driveline, distributes power between the front and rear wheels, always according to the prevailing situation. The split in the basic setting is 40 percent to the front wheels and 60 percent to the rear. This slightly rear-biased torque split has been chosen to place even greater emphasis on the sporty, dynamic character of the Audi S6.
If the surface conditions change . for instance if they are wet or slippery, or if the car is driven onto a different type of road surface . the purely mechanical differential responds without any delay; depending on the road situation at any given moment, it can divert up to 85 percent of power to the rear wheels or as much as 65 percent to the front wheels. If a wheel on one axle spins (wheel slip), it is moreover brought under control by the Electronic Differential Lock EDL, which applies the brakes.
The electronic stabilization program (ESP) shuts down in two stages: when the ESP button is pressed once, only the ASR traction control system is deactivated; ESP remains active, to stabilize the car if needed. The instrument cluster briefly displays "ASR off" and the ESP symbol remains permanently lit. This mode stays active in the S6 until ASR is switched back on by pressing the ESP button a further time. On the S6, ASR does not cut in automatically once a defined speed is exceeded (as is the case on the A6 / A6 Avant). If the ESP button is pressed for longer than three seconds, all ESP functions are switched off. Only the electronic differential lock EDL and ABS remain active. Pressing the ESP button a further time switches all ESP functions on again. As a result, the desired degree of electronic assistance can be determined by the driver via the ESP button. Without ASR traction control, the degree of stability can, within certain limits, be determined by the driver via the accelerator pedal. This permits a decidedly sporty driving style if desired.
The drivetrain concept of the new S6 always ensures that the enormous forces generated by the V10 engine can genuinely provide efficient, minimal-loss propulsion, something that vehicles with one driven axle only rarely achieve. It is consequently able to develop and use high levels of power all the time.
Chassis
Firmer and more spontaneous
The dynamic suspension layout of the new Audi S6 is based on a technology that has already demonstrated its sports caliber in the most challenging of conditions: the refined four-link front suspension acknowledged as a typical Audi feature and the self-tracking trapezoidal-link rear suspension carried over from the Audi A8. This combination gives the S6 one of the most complex and efficient rear suspension layouts currently available. In terms of its kinematic behavior, this technical element already provides a foretaste of the sporty, active characteristics of the Audi A8 . measures that enhance directional stability, steering precision and handling convenience. The entire layout is designed in such a way as to produce a neutral response with a moderate tendency to understeer when the very high limits of handling are approached.
The principal components of the chassis feature lightweight aluminum construction, resulting in decisively lower unsprung mass. The targeted use of sheet steel, on the other hand, achieves optimum rigidity wherever it is required. In selecting specific materials and manufacturing methods for each individual suspension link, Audi's engineers have been able to ensure that the chassis represents an optimum blend of low weight, high rigidity and safety.
As a reflection of its explicitly sporty character, the suspension settings of the S6 have been made firmer, even compared with the A6 sports suspension, and at the same time assures a high standard of comfort for long-distance driving. As the elastokinematics have likewise undergone comprehensive modifications, the
Audi S6 is always noticeably more agile; meanwhile, driving stability and traction have been further optimized.
The Audi S6 is equipped with 19-inch cast aluminum wheels of a 5-arm wing design. The wide tires are of size 265/35 R19.
An 18-inch brake system assures supreme braking performance and is resistant to fading even under high loads. Its four large discs are ventilated, the discs on the front wheels measuring 385 mm (approx. 15.1-in.) in diameter and those at the rear measuring 335 mm (approx. 13.1-in.). The brake calipers are painted black, and are adorned with an exclusive S6 badge at the front.
Design
Supremely athletic presence
The models in Audi's S range have traditionally epitomized systematic sports appeal. This applies in equal measure to the new S6, which now dynamically hones the visual impact made by the A6. These models are renowned for their inherently light and elegant character . their very distinctive aesthetic appeal reflects their exceptional status as sports models in the luxury class.
The S6 cuts an even more supremely athletic figure out on the roads . but without even the slightest hint of aggression. The most striking differences are to be found at the front end. The eye-catching single-frame grille displays the S6 emblem, and its vertical aluminum-look struts are of a double design by way of further differentiation. There is an air inlet beneath the grille. A spoiler lip at the front end of the car provides an additional sporty highlight.
Another innovation in the front bumper is a pioneering development in terms of both safety and style: the separate LED daytime running lights, each of which consists of five white light-emitting diodes and consumes only a minimal amount of energy. When these light strips are switched on, the effect is utterly distinctive: they make it incredibly easy to identify the new Audi S6, and the low-down position of the daytime running lights gives the car a dynamically flat appearance. To accommodate this concept, the fog lights have been incorporated into the main headlights, the covers of which are tinted grey. Audi Bi Xenon adaptive light with dynamic cornering light is standard. The rear light units incorporate LED brake lights as standard.
The front wheel arches are flared by 14 mm (approximately .5-in.). The door trim strips are likewise wider, to accentuate the .S. characteristics, and are painted in the body color. Other striking differentiating features are aluminum door sill trims bearing the S6 logo at all four doors, the rear spoiler integrated subtly into the luggage compartment lid, aluminum-look exterior mirrors, the V10 emblem at the front beneath the side turn indicators, and an S6 logo on the rear end. The vehicle's tail end also displays a color-contrasting diffuser in the bumper and the four ellipsoidal tailpipes of the exhaust system, with its notably sporty acoustics.
Interior
Luxury and refinement in detail
In the same way as the body's styling, the interior of the new Audi S6, too, reflects a character of dynamic elegance and high quality . from the architecture of the driving area that surrounds the driver to the Audi MMI user interface (Multi Media Interface), which remains unequalled by any competitor thanks to its logical, intuitive operating principle.
The luxurious interior of the S6 features specific highlights. For instance, there is a new generation of sports seats. They have integral head restraints and pronounced lateral supports, and are upholstered in Silk Nappa leather. The front seats are electrically adjustable in multiple directions as standard, and include a lumbar support. The three rear seats, which display the same material, are equipped with L-shape head restraints which afford a better view to the rear.
The three-spoke multifunction leather sports steering wheel with the S logo is a typical example of the hand-crafted character that Audi so often achieves in its attention to detail: it is trimmed in smooth leather and displays a color-contrasting double seam with a special seam pattern.
The shift paddles, which are mounted to the steering wheel (in other words, they move as it is turned), have an aluminum-look finish. The selector lever, too, has an aluminum look and is trimmed in smooth leather.
Birch Gray wood trim is used as the material for the applications, while carbon fiber can be selected as an option. The material on the instrument panel represents a further innovation in the S6: it goes by the name of "Flexmetallic" and correspondingly exhibits an anthracite-colored metallic surface characteristic. Anthracite is also the predominant color featured on the other sections of the instrument panel. The center console, on the other hand, is in black.
The instrument needles and numbers are in white, using characteristic S-style italics; the dials are in dark grey.
The standard color Driver Information System (DIS) has an additional digital speedometer in the new S6. The Audi MMI with 7-inch monitor in the cockpit is likewise included as standard. There is a welcome screen customized specifically to the S6. The MMI furthermore integrates the controls for the standard Bose surround sound 13-speaker stereo system with 6-disc changer. The optional tire pressure monitoring system displays the pressure and temperature of each tire individually in the S6.
Audi is likewise innovative when it comes to phoning in the car. All S6 models in the US and Canada will have universal phone preparation with Bluetooth interface as standard equipment.
Safety
Whereas the high standard of active safety of the new Audi S6 stems principally from its superior engine power, pioneering quattro four-wheel drive and ESP, the sporty range-topping model also boasts a full complement of passive safety systems. This model comes complete with a package of restraint systems that are perfectly matched to the highly rigid aluminum body, including two full-size front airbags, side airbags for the front seats and large-area Audi Sideguard curtain head airbags. Side airbags for the rear seats are available as an optional extra. All five three-point belts in the Audi S6 are of course fitted with belt force limiters; belt tensioners are fitted on the front seats as standard.
