Go Back   United Bimmer Community - BMW Forum > UnitedBimmer- Model Categories > Other Makes And Models
Other Makes And Models discussion of all other makes and models
Old 12-14-2005, 08:21 PM   #1
Rate My Car: 183 / 337
Hurricane 4x4 - 16 cylinders, 11.4 litres and four wheel steering
i was looking at the website cellsdog posted and i found this, crazy!
http://www.gizmag.com/go/3599/
January 10, 2005 Jeep dropped a showstopper at the opening of the 2005 North American International Auto Show in Detroit today when it unveiled a radical off-road machine with TWO 5.7 litre V8 engines and a turning circle of ZERO! There are two 5.7-liter HEMI engines in the vehicle: one in the front and one in the back. Both engines deliver 335 horsepower and 370 lb-ft of torque . a total of 670 hp and 740 lb-ft of torque. Both HEMI engines in the Jeep Hurricane are equipped with the Chrysler Group Multi-Displacement System (MDS). Depending on the driver.s needs, the Hurricane can be powered by 4-, 8-, 12- or 16-cylinders. All of that translates into buckets of torque for climbing obstacles and, well having fun. On the tarmac, it has the power and traction to move from 0-60 in less than five seconds.
The power is delivered through a central transfer case and split axles with a mechanically controlled four-wheel torque distribution system. The front and rear suspension is short/long arm independent with 20 inches of suspension travel, controlled by coilover shocks with remote reservoirs.
The vehicle has 14.3 inches of ground clearance, and incredible approach/departure angles of 64.0 /86.7 degrees. These are nearly vertical angles . combined with 37-inch tall tires, so the Hurricane won.t meet much that it can.t climb.
The Jeep Hurricane is the only vehicle on the auto-show circuit that provides its own turnable feature. The vehicle features a turn radius of absolutely zero, thanks to skid steer capability and toe steer: the ability to turn both front and rear tires inward. In addition, the vehicle features two modes of automated four-wheel steering.
The first is traditional with the rear tires turning in the opposite direction of the front to reduce the turning circle. The second mode is an innovation targeted to off-road drivers: the vehicle can turn all four wheels in the same direction for nimble crab steering. This allows the vehicle to move sideways without changing the direction the vehicle is pointing.
Clearly, this could mean a huge difference for the driver when the nearest assistance is four hours away and changing direction in minimal space can mean the difference between an afternoon of adventure and a distress call back to the trailhead. The multi-mode four-wheel steering system offers killer performance and maneuverability.
The one-piece body is shaped of structural carbon fiber, and forms the chassis that would be offered through a traditional frame. The suspension and powertrain are mounted directly to the body. An aluminum spine runs under the body to both connect the underside and to function as a complete skid plate system.
The design is lightweight with high strength, and it boasts functional appearance. Jeep Hurricane is an honest, minimalist approach to its design augmented with the Jeep signature seven-slot grille, two seats and no doors. On the inside, occupants will be surrounded by exposed carbon fiber and polished aluminum with Black Thunder and Tiluminum accents. Specifications: Weight (estimated): 3,850 lbs. (1,746 kg) Length: 151.8 inches (3,856 mm) Wheelbase: 108.1 inches (2,746 mm) Front Overhang: 25.0 inches (635 mm) Rear Overhang: 18.7 inches (475mm) Width: 80.0 inches (2,033 mm) Height: 68.2 inches (1,732 mm) Track, Frt/Rr: 67.5/67.5 inches (1,715/1,715 mm) Engine: two 5.7-liter HEMIĀ® engines Transfer Case: Custom multi-mode with 1:1, 2:1 and 4:1 ratios Transmission: 5-Speed automatic Front and Rear Suspension: Long-travel, short/long arm independent Ground Clearance: 14.3 inches (363 mm) Break-Over Angle: 31.5 degrees Approach/Depart Angle: 64.0/86.7 degrees Tire Size: 305/70R20 Wheel Size: 20x10 inches
Old 12-14-2005, 08:44 PM   #2
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Yea i saw that at the autoshow last year, Unfortunatly for jeep they are on my shitlist so i'm not really interested in anything they have.
Old 12-15-2005, 04:57 AM   #3
Rate My Car: 137 / 337
Wonderful......most idiots can't drive as is, now this Most new cars should require a pilots license! Most of these clowns can't set their f#$%king clocks. IE: can you say "cell phone?"
Old 12-15-2005, 12:52 PM   #4
nick_318is
nick_318is's Avatar
^can i really get a bumper sticker like that? I really agree most people suck at driving in general I think everyone needs to take at least one class where they learn to drive, at least then they will have a better idea of what can happen, i.e drivers schools.
Old 01-16-2006, 05:39 PM   #5
Akuma
Rate My Car: 6 / 337
gobsmacked! got my respect because it has 2 engines!
1989 BMW E30 325i Cabriolet.
