Non BMW General Automotive DiscussionTalk about any other car make here
Electronic Overdrive
I have electronic overdrive in my 99 solara. I was wondering how to use it, and how it works. There is a little button on the automatic shifter and when i press it it says o/d off.
Also, i was wondering which ipod car adapter i should buy, i want it to charge as i am using it.
O/D off is better for around town and o/d on is good for highways
for the ipods. no clue. dont own one
You know your a drunkard if you... Think box wine is great; eagerly awaiting box whiskey.
Originally Posted by RSF5
Well yeah, the BATFE is like the Anti Hoppy.
Well hey, hey Mr. Policeman
Bet I can drive faster than you can
Come on Hoss, let's have some fun
Go on shoot me with your radar gun
You look bored and I sure am
Catch me if you can.
Your Ride: e36
i have an aux input on the back of my headunit, so i have a wire from there to my ipod, and then a charger from the eletrical outlet to the bottom of my ipod.
there are other ones such as the fm trasmit.... i hate them... some work alright it seems like....
as far as i know all O/D does is leave your car in a lower numbered gear(ie. 4th instead of 5th) so that u dont have to push the gas as hard to get it to shift. Its for gas saving i guess.
Correct me if im wrong though.
also with the ipod, just google it, and im sure you can get some info. If its a factory head unit you can prolly find an adapter which you can install. Just search a little.
od is a higher gear. on old manual cars it would be 1-4 then OD the od was equivalant to a 1/2 step up in terms of gears. its normaly a seperate unit to boost the over all drive ratio to cruise better
Around town I would suggest shutting it off. Most OD come in around 40-45mph and it automatically shifting in/out of OD constantly will shorten its life. Its a wonderful gas saver on the highway though. Just my 2 pennies...
