Go Back   United Bimmer Community - BMW Forum > UnitedBimmer-General BMW Topics > Non BMW General Automotive Discussion
Non BMW General Automotive Discussion Talk about any other car make here
Old 09-25-2007, 07:25 PM   #1
bcmcali
Your Ride: 1992 325i
#2 plug is wet
The #2 plug on my 92 325i is wet with gas. I started my car one day and it was running rough. After checking the plugs noticed a crack in the #2 coil. I replaced it in the dealership parking lot. It ran 90% for 15 min. The coil fires on a different wire. Any thoughts.
Old 09-25-2007, 10:16 PM   #2
Rate My Car: 183 / 337
what do you mean 'it fires on a different wire'... was it wet before or after you replaced the coil? did you check your injector?
Old 09-26-2007, 09:36 AM   #3
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
+1 We're going to need some more information to start diagnosing over the internet.
Old 09-26-2007, 08:06 PM   #4
bcmcali
Originally it started running rough, then a small amount of the plastic on coil #2 melted (smelled it burning), it also had crack in the bottom.. I then replaced the #2 coil and it ran for 15 min pretty good for 230,000 miles. It started running rough again, and after checking the plugs, #2 is wet with gas, the one with the new coil. Ok, my friend instructed me to test the firing by removing the plug/coil assembly and putting it on #3 grounded to see if it would fire, it did. And the #3 plug/coil assembly wouldn't fire connected to the #2 wire.
Old 09-27-2007, 04:38 AM   #5
Rate My Car: 106 / 337
Sounds like the wire. Open up the long wiring box that runs alongside the fuel rail. You have to carefully undo the snaps to release the cover- try not to break them. Inside you'll find the ignition wiring. These wires are very flimsy, and often times you'll find one or more wires frayed, chafed or broken, in need of repair.
Spark plug replacement & compression test DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 21 10-18-2010 10:22 PM
1992 318i plug wires chandra E36 3 08-15-2007 11:47 AM
Oil covering spark plug - help! larryglover@gulfviewllc.c E36 3 05-07-2007 09:53 PM
Oil Drin Plug andykay E46 6 05-07-2006 11:27 AM
Cigarette plug Rooz E36 4 12-27-2005 11:43 PM
