Go Back   United Bimmer Community - BMW Forum > UnitedBimmer-General BMW Topics > Introductions and Greetings
Introductions and Greetings Sponsored by: match.com
New to the site? introduce yourself here and tell us a little about you and your sled. This is the "Hi, my name is and i drive" forum.
Old 11-09-2012, 10:24 AM   #1
Laguna318i
Your Ride: 1991 E30
Restoring/ upgrading 91 E30 318i
Good morning UBC! My '91 318i has been and continues to be bold and faithful at 309k miles. Its about due for interior (seats), new paint and tire/wheel upgrades. We'll consider an engine swap when the old machine shows signs of tiring. Any suggestions on seats and wheel/tire combo that will fit? 16x7 wheels?
I solved an electrical problem yesterday. #10 7.5 amp fuse kept failing (backup lights, water temp, gas gage). When the car was on the rack to re-weld the rear muffler, i sneaked under and used the light to inspect the reverse light cable. It was mangled from contact with the drive shaft. Anyone know the part number for the backup light cable?
Btw, the common break at the rear muffler is probably due to not being supported properly. When it breaks again and the muffler is replaced, the installer will firm up the supports.
FYI, if you need muffler or cat in So Orange County, go to Rod's Muffler on Camino Cap in SJC. When my E30 failed smog last January, he installed a new cat for $225. The smog test numbers came in so low that the tester feared reprisal by the state's draconian regulators.
Old 11-17-2012, 06:48 PM   #2
DEATH2000
DEATH2000's Avatar
Rate My Car: 111 / 340
Welcome to United bimmer.
I'm looking forward to seeing pictures of the car and your work on it.
VIEW MY E36 BLOG HERE
Thoughts on a 91' 318i tsweers89 E21, E30 19 11-29-2012 04:17 PM
91' e30 318i shearing noise during idle 510markman510 E21, E30 3 07-26-2012 10:07 AM
E30 318i Will Not Start mmihacsi E21, E30 17 12-09-2011 07:44 AM
Starting problem - cold weather - e30 318i MJanosh E21, E30 0 12-14-2009 05:18 PM
E30 318i (1987) starting problems 2002E30BaurTC E21, E30 2 02-12-2008 12:40 AM
