Go Back   United Bimmer Community - BMW Forum > UnitedBimmer-General BMW Topics > Introductions and Greetings
Introductions and Greetings Sponsored by: match.com
New to the site? introduce yourself here and tell us a little about you and your sled. This is the "Hi, my name is and i drive" forum.
Old 01-22-2012, 01:17 AM   #1
brianbruce
Your Ride: 1997 316i compact
E36/5 1997 316i compact DIY info ( light bulb replacement)
I would like to change some blown out bulbs in my trunk and behind my heat and blower panel. Can anyone advise me? I am also trying to find any information on DIY pdf, photos, software for my 316i compact (1997). I have a Macbook, not a pc.
Thank you for your time,
Brian
Old 01-23-2012, 09:16 PM   #2
DEATH2000
DEATH2000's Avatar
Rate My Car: 111 / 340
Welcome to United Bimmer! I have posted the Bentley Service Manual and Haynes Manual Dow load links in the E36 section. Please feel free to download scoot for your reference. Our Knowledge Base has an excellent section of DIY writeups with more on the way. Feel free to have a read through them and see if they help.
As for the bulbs in your taillights: Their is a plastic cover on the back of the taillight inside the trunk. The cover has a small dial in the center of it you rotate and the cover pulls off. Each bulb sits in a lamp socket inside the taillight housing. The lamp sockets rotate and pull out. This gives you acess to the bulbs. The bulb turns and can be pulled out. Check to make due the bulb sits securely in the lamp socket and doesn't have any movement. The lamp sorts wear out over time and can need replacement. I've replaced two in my car.
Any fitter questions or if you need a picture for reference let us know. We're here to help.
VIEW MY E36 BLOG HERE
DIY For BMW Cup Holder & Console LED Lights (Pictures) delmarco BMW OEM Parts Department DIY's & FAQ's 9 12-08-2008 07:52 PM
LIGHTING FAQ and lTUTORIAL habbie Lighting DIY's 0 09-24-2007 12:33 AM
