Go Back   United Bimmer Community - BMW Forum > UnitedBimmer-General BMW Topics > Forced Induction
Forced Induction Sponsored by: SmartAutoWarranty.com
Discuss Forced Induction on BMWs with SmartAutoWarranty.com (turbos and superchargers).
Old 11-05-2006, 04:53 PM   #16
defkon99
defkon99's Avatar
Rate My Car: 50 / 340
Your Ride: 1993 E36
Originally Posted by B_w.
is yours a 325? i think a 35r might be too big, maybe if you got the smaller exhaust housing, .63 i think. i went with a .82 for my 328. another option is the sc61. i believe it has the same compressor as the 35r except is not dbb and has a different exhaust housing. it is a very capable turbo and is less $$$ than the 35r. dbb will help spool greatly.
it also depends on how you want your car to drive. do you want it to pull hardest in the topend, like your 325 does now, or do you want more low end power? i think going with a laggier turbo will just help with traction issues down low. if you want quicker response go with a smaller exhaust turbine, and for a bigger topend go with a larger housing.
yea it 325i m50
man i wish i had yur knowledge man if maybe we can do like a IM sometime i or go to Ub chat id like to ask sokme questions.
Old 11-05-2006, 06:33 PM   #17
matimus
matimus's Avatar
Your Ride: E30/S50 GT35R+ E30M3
i'd def go with the GT3071R
for a good, fast steet car.
Old 11-05-2006, 08:10 PM   #18
defkon99
defkon99's Avatar
Your Ride: 1993 E36
sounds like a dumb question but what would be the a/r or the example .70 or .71 <-- thats where im having trouble
Old 11-05-2006, 09:33 PM   #19
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
Sooo
I'm guessing we found this book?
Old 11-05-2006, 09:48 PM   #20
defkon99
defkon99's Avatar
Your Ride: 1993 E36
Originally Posted by BMWLotAttendant
Sooo
uhhh yea. 5th post man.
Old 11-05-2006, 09:51 PM   #21
BMWLotAttendant
Good deal!
Old 11-05-2006, 10:00 PM   #22
B_w.
Rate My Car: 60 / 340
Your Ride: turbo e36
Originally Posted by defkon99
yea it 325i m50
no problem
aim: bmwbyron
i am usually on most of the time
Old 11-21-2006, 01:18 PM   #23
///M Power
Rate My Car: 24 / 340
Your Ride: 95 m3 turbo
A/R is your area: radius ratio. Area being the cross sectional area at the inlet or outlet depending hot or cold side. The radius comes from the measurement from the center of this cross sectional area to the center of the turbo. The larger your area to radius ratio is, the more pwoer you could make, but this will also has the negative effect that if you go too big you'll basically take a lifetime to spool (if you even can).
Trump Files $5 Billion Law Suit komodo United Off Topic  **FOR MEMBERS ONLY** 13 01-25-2006 11:48 PM
Google Goes Beyond Book Scanning komodo United Off Topic  **FOR MEMBERS ONLY** 1 11-28-2005 03:58 PM
Microsoft to Get into Book Scanning komodo United Off Topic  **FOR MEMBERS ONLY** 6 11-06-2005 10:58 PM
Burj Al Arab DUBAI!!!!! delmarco United Off Topic  **FOR MEMBERS ONLY** 21 06-06-2005 10:47 PM
