Go Back   United Bimmer Community - BMW Forum > UnitedBimmer-General BMW Topics > Forced Induction
Forced Induction Sponsored by: SmartAutoWarranty.com
Discuss Forced Induction on BMWs with SmartAutoWarranty.com (turbos and superchargers).
Old 04-20-2005, 08:20 PM   #1
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 72 / 329
Your Ride: 1995 M3
Supercharger rebuilding
Quick question... what kind of gains can you expect out of a supercharger for my car? Turbos claim they'd put me around 300...
And s/c'ers are better for the car and your engine will last longer, right? Do you need to reinforce any internals, or is it just popping it on and you're done?
What about tuning... you always hear about turbo tuning, but I don't think I've ever heard of tuning for an s/c....
Thanks.
Old 04-20-2005, 08:56 PM   #2
///M Power
Rate My Car: 23 / 329
Your Ride: 95 m3 turbo
Gains all depends on the amount of boost. Boost high enough and you will absolutely need to reinforce the internals. A supercharger does nto necessarily mean you engine will last longer at all, but rather actually puts MORE stress on your engine. Just look at how a supercharger works and what it works onversus what a turbo works on and you will understand.
Although, a supercharger will be a single unit instead of the plethora of pieces involved in a turbocharger. The mroe pieces you have the harder it may be to locate a problem. A single S/C unit is easier to maintain for that specific reason.
Old 04-21-2005, 01:48 PM   #3
dwrx04
Your Ride: your mama
Superchargers are known for there reliability. While your logic is correct, a supercharger puts no more load on your car then an ac pump. There is an external pulley that spins a step up gear inside the sc which acts as a tranfer case and spins the impeller at higher rpms and substantially faster than the external pulley.
As to komodo's question, superchargers normally boost between 6-9psi over atmospheric pressure(at sea level is about 14.7) The only tuning you will need in most cases is a boost timing retard chip that retards the engine's ignition timing under certain conditions to prevent detonation. With some kits, detonation is not a concern, in which case the kit will not include. A concern some people have when using a supercharger is that they think it will increase the engine's compression to the point that it will cause detonation that is the purpose of the chip. The only other thing you have to watch is you A/F ratio. You will prolly make around 300hp to the crank which is the best bang for your buck IMO.
I AM THE VANILLA GORILLA
member of the..."The bears can smell the menstration...................sercret society for really hung men."
I AM HETEROSENSATIONAL!!!!!!!!!1!!!eleven!!!!11
Originally Posted by CMT View Post
*sniff sniff*
DDm smells like a Jim Powell venture to me. No thanks. I'd be afraid of the mucus trail the call would leave all over my phone. Although in all reality you would probably be fine ordering from them, I wouldn't patronize the place if someone knocked on the door and paid me to run their product
Old 04-21-2005, 02:28 PM   #4
Addicted?
Title: 350z
Your Ride: 2003 350z Track Edition
with a supercharger you dont always need to do some interals... they cant hurt but i have heard not always neccassary. AA tuning has put there supercharger on a stock motor with 150 thousand miles with no internals and it ran fine.
As for a turbo claiming 300hp on your motor, that is very possible, it is also possible for it to make 350 400 500hp etc "throwing" a turbo on your car doesnt just give you X amount of HP, the bigger the turbo, better tuning, reinforced internals etc can all help how much boost you run meaning more HP, even the higher octane gas will make you run more hp. You have to remember with turbos you wont always be running 300hp, When you go to a track you could say put boost to 15 psi and run 100 octane gas... but when you leave to drive home you will probably run 7-9 psi on regular gas, which will lower you hp reading... as we have said before turbos are pretty complex specially on cars that dont come turboed....
Are there exceptions? yes you see those honda civics driving around town with there HUGE front mount and a loud ass BOV? yeah they are running 4psi and my 325 can still walk on them, they spend maybe 3500 on a "kit"
the aa supercharger says it puts out about 322 hp (to the crank) and its only 5700 bucks... i would defintaly go with something along this lines whether it be aa or not. after i swap my m3 motor ill eventually look into F/I a turbo would be nice, but i think ill end up going with some sort of s/c and have over 300hp and be happy
David
EDIT just saw the rest of your question...
adding any kind of f/i technically isnt great for your engine... but the car will die one day anyways so who cares... also you can always get it rebuilt and built back up etc.. .Dado is getting his whole moto rebuilt right now.
As for tuning a supercharger yes you can do it, i think aa might send some stuff to make the s/c run right... when i go with a supercharger ill probably have some other mods to my car, and will want my air/fuel map pretty smooth, granted tuning is a SHIT load of money im going to spend the thousands of dollars to get my car tuned to all my mods/all the extra air for the S/C
Old 04-21-2005, 03:03 PM   #5
komodo
komodo's Avatar
Your Ride: 1995 M3
Cool, that actually helped a lot... I didn't know all that.
Other than AA Tuning, what are some other s/c's out there? AA Tuning and Dinan are the only ones I know about.
Old 04-21-2005, 10:21 PM   #6
Rate My Car: 80 / 329
IMO Adding boost without reinforcing main bearings is risky unless you drive super careful
Old 04-21-2005, 10:38 PM   #7
Rate My Car: 173 / 329
btw, even though this is not related to superchargers, did you consider cams? liek m3 cams or something, b/ci heard those r nice too, and those dont put any stress on ur engine
Old 04-21-2005, 10:52 PM   #8
komodo
komodo's Avatar
Your Ride: 1995 M3
Hum, but don't cams cause a rough idle?
Old 04-21-2005, 11:09 PM   #9
ChrisWorrell
Your Ride: 2004 330i
depends on the cam lope, you can get mild cams where it wont shake the car alot
Old 04-21-2005, 11:27 PM   #10
maybe if u get aftermarket cams, but m3 cams, im almost posative, althought i havent tried them
Old 04-22-2005, 02:17 AM   #11
Addicted?
Title: 350z
i personally love the rough idle some cams give to cars... with exhuast there isnt a better sound out there... anyways they are a pretty good alternative... spendy either way
David
Old 04-22-2005, 12:46 PM   #12
B_w.
Rate My Car: 65 / 329
Your Ride: turbo e36
if you upgrade to m3 cams and the software to run the cams there should not be rough idle.
can you super charge or turbo charge an m52 with m3 cams? is it just a question of getting software to run it properly?
Old 04-22-2005, 03:14 PM   #13
^^ im pretty sure u can.. and seconldy komodo, jrhaile did it, i dont think he has rough idle, as seen from his videos, the only other reason u may have rough idle is if you havent done ur timing correctly
Old 04-22-2005, 05:03 PM   #14
Addicted?
Title: 350z
m3 cams dont really give your a car a rough idle.. i believe the shrick might..but they are aftermarket parts.. i dont have much information on cams but i beleive it has to do with the degree of the cam etc that makes your car idle rough (which isnt a bad thing, and as i said before, with exhuast sounds awesome haha) anyways im sure you can run a supercharger with cams.... just a matter of getting it tuned...
That would be a kick in the arse since cams will kick in in the higher rpms and the supercharger going all the way through.... can you say vroom vroom
David
Old 04-22-2005, 06:22 PM   #15
///95M3
not on a bimmer. I have ridden in many M3's with Schrick cams and injectors and the only difference is the slower, deeper rumbling of the engine. It sounds better and feels better, not at all rough. If I were you I would consider some exhaust. Your car sounded awsome from the front but alittle shakey and rattlie from the back.
Current standings: 98 M3 Track car
Mods: suspension, i/e/fly only
1/4th mile: 13.7@101 on 235/40 streets
Rd Atlanta: 1:44's on RA1's, 1:46 st.trs
Past cars
95 M3 3.2obd1
540i/6
Supercharge? e_andres55 Forced Induction 57 05-02-2011 12:30 PM
What's the cost of rebuilding the E36 M3 Motor? chris3896 E36 1 01-07-2008 01:37 PM
'95 325i, Supercharger question Avlany E36 22 03-26-2006 06:58 PM
Dinan X5 4.4i Supercharger System longodj X Series (X3, X5,X6) 3 05-17-2005 12:22 AM
