Forced Induction
Sponsored by: SmartAutoWarranty.com Discuss Forced Induction on BMWs with SmartAutoWarranty.com (turbos and superchargers).
Your Ride: 1998 323is
Supercharger and Turbocharger
Turbochargers and Superchargers are air-compressors that are used to suck more air into an engine and compress the air, compressing the air allows more air to go into each cylinder, this also allows more fuel to go into the cylinder which means you get more power from each explosion in the cylinder, the amount of air that the compressor pushes into the engine is measure in pounds per square inch(psi)
A supercharger is driven by a belt connected to the engine like an alternator
A turbocharger uses exhaust gas to spin it's turbine
Shahab's summary is right, and also explains why turbos have lag, having to wait for the exhaust gasses to start flowing. Smaller bi- turbos help by reducing turbine rotation inertia
Your Ride: your mama
you can get lag from a lot of things like have a small turbo and a FMIC you can also get it from heat soak.
__________________ I AM THE VANILLA GORILLA
member of the..."The bears can smell the menstration...................sercret society for really hung men."
I AM HETEROSENSATIONAL!!!!!!!!!1!!!eleven!!!!11
Originally Posted by CMT
*sniff sniff*
DDm smells like a Jim Powell venture to me. No thanks. I'd be afraid of the mucus trail the call would leave all over my phone. Although in all reality you would probably be fine ordering from them, I wouldn't patronize the place if someone knocked on the door and paid me to run their product.
btw guys i said anyone else? so others can add info as necessary, i'm not expert, this is just to help people who don't know that mutch about forced induction
this link is great it will answer any question you will have on turbos. The site is kinda weird to navigate through but once you figure it out ur golden.
Yeah so now that you have read all that you know everything about cars WOOOHOOO
*sniff sniff*
Your Ride: 88 325is
The only problem I see with superchargers is the fact they can use up to 20% of thier power output simply for operation. Of course, this problem can be opposed by the problem of turbo lag.
