Go Back   United Bimmer Community - BMW Forum > UnitedBimmer-General BMW Topics > Forced Induction
Forced Induction Sponsored by: SmartAutoWarranty.com
Discuss Forced Induction on BMWs with SmartAutoWarranty.com (turbos and superchargers).
Old 05-14-2007, 12:07 AM   #1
92 325i
Your Ride: 92 325i
Injector size
Hello there. I have a 92 325i that i was going to turbo. I am building my own kit. I already have a t3/t4 hybrid turbo with a 8psi wastegate setting. From everything i can tell, this if tuned right could make about 300hp But my question is what size injectors should i use? 26lb? 30lb? 36lb?
As well does anyone know of a website that sell turbo manifolds for the M50 with an external wastegate pung?
Thanks
Old 05-16-2007, 10:46 AM   #2
92 325i
Your Ride: 92 325i
In my opinion im thinking 30lb injectors are the right size but would appricate any input
Old 05-16-2007, 02:32 PM   #3
///M Power
Rate My Car: 23 / 329
Your Ride: 95 m3 turbo
300 bhp?
30 lb/hr sounds appropriate.
This is a very loose uncalculated estimate.
Old 05-18-2007, 06:05 PM   #4
B_w.
Rate My Car: 65 / 329
Your Ride: turbo e36
42 lb green ford motor sport injectors would be a good bet. lots of room to up the power and they are cheap and readily available.
for the manifold contact techno555 on bimmerforums.com and for tuning contact e36'n on bimmerforums.
give us some specs on your turbo
Old 07-01-2007, 05:50 AM   #5
card counter
card counter's Avatar
Your Ride: 97 328
I have to agree 42lb would be best and room to grow if needed
www.bmwturbo328.com
704whp stock internal 2.8 10.7@137
996whp fully built 2.8
Old 07-25-2007, 09:29 PM   #6
TechniqueTuning
Title: UB Supporting Vendor
Your Ride: 2001 BMW 330ci Turbo, 2002 X5 3.0
Injector size depends on how much power you want to create. On a 2.5L with ~8psi of boost, I'd stick with 24lb/hr injectors. If you want more boost than that, then you'll have to go larger on the injectors. I don't like putting too big of an injector in, because then idle quality may begin to suffer.
Nick Glantzis
Technique Tuning Inc.
BMW Turbo Systems and Forced Induction Tuning
Old 01-19-2009, 11:47 AM   #7
cmill95
Your Ride: 85 bmw 635csi, 95 t-bird s/c
figure this, I've got 38s on my supercharged 3.8L, and that's with about 13LBS of boost from the factory!
don't go too big because when they cycle in a non-boost environment they'll spew rather than spray at lower fuel rail pressures.
what duty cycle are you planning on having the injectors spray at when you're at full boost? hopefully no more than 80%!
I'd go with the same with your turbo conversion for 300 hp at about 45 lbs rail pressure.
bigger injectors for turbos than S/Cs btw.
Chris
