E46General discussion and technical help for 1999-2004 3 series cars.
Your Ride: 2003 330i
Reservoir doesn't.
Not long after I got my Precioussss, the windshield fluid indicator came on. I thought "How unlike them to not fill the reservoir on a
'certified pre-owned.' " So I fills it up, and two days later it's low again. Dealer say's bring it in and they'll fix it for free. That wouldn't be such a bad deal if they gave me an M6 for a loaner. Anybody else got a hole in their bucket?
Mods: Ping Eye 2 Black Dots in the trunk. Considering Anti-Spouse Ejection System by Whamo.
Garantee its the rubber o-ring that the pump mounts to. It could also be the pump, Ive replaced them along with the washer.
If you open your hood and you have headlight washers check the small resivor thats mounted to the strut tower on the right side. If you see dryed blue fluid thats run down it that also more then likely leaks or will start.
Thanks Antiburn, that's exactly what I saw. No wet spots under the car, just some dried blue deposits. The guy at the service dept. said as much but they want to fix it themselves rather than give me an o-ring. Oh well, I'll just set up an appointment and drive a loaner for half a day. Break my heart! Please don't throw me in the briar patch! Don't make me drive another BMW! AARRGH!
Your Ride: 1997 Camry CE
Don't know, I'll find out this afternoon. Maybe it'll be an M5 or a 745il
(NOT!) Anything but an X. Actually, a Mini would be the perfect loaner car; I could drive the shit out of it, use very little gas, not worry about the tires, shocks, and bushings. Hell, I'd take the rest of the day off and go to Talahina drive.....
