Old 07-31-2006, 07:11 PM   #1
curtishead
curtishead's Avatar
Your Ride: 2003 330i
Weatherstripping Noise
My '03 330i makes a noise like a child's toy horn at 70mph. It's not too loud, just annoying. It comes from the front of the drivers window/door and goes away when I roll the window down. ( I don't know if the window is the culprit or the pressure change stops the door from squealing.) It is probably the weatherstripping but I wanted to know if anybody else had heard/fixed this.
Free beer to the right answer!
Old 07-31-2006, 10:50 PM   #2
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
Mine gets wind noise at ~100 from passenger rear ...
But yours does sound like a weatherstripping issue
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 07-31-2006, 11:33 PM   #3
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
Yeah that does sound like the seal in the door could have come undone. Has it been driven in the rain? That will definitely tell you.
Old 08-01-2006, 12:10 AM   #4
Rate My Car: 137 / 337
Take it to a DIY car wash and pressure wash around the window in question - that'll test the seal (and where it's leaking)
Old 08-12-2006, 02:19 PM   #5
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
Bmw weather seals can get dry over time, causing the rubber seal to rub onto the window. Dont use wd-40 or a lubricant like that beucase your windows will get streaked. Get some paper towels and some window spray cleaner, the foam spray. I wouldnt try windex but if thats all you got, go with it.
Wet the towel, and clean off the seal that the window touches. Also spray sylicone wiped onto your door seals would help reduce the noise.
The window creak noise you hear is a known complaint on x5 rear tail gates and all early model x3 window seals, like yours.
Old 08-12-2006, 03:29 PM   #6
Rate My Car: 183 / 337
weatherstripping on an 03? meh...
Old 08-12-2006, 04:02 PM   #7
The "stealerships" sell a product called "Gummi-Fledge" for seals. excellant stuff
Old 08-12-2006, 07:03 PM   #8
Antiburn
Antiburn's Avatar
Theres also a product that is supplyed by parts called "rubber care" made by wurth. They say on the back of the can that you can use it on all rubber products like seals and even your tires.
Small noise from under the hood ///Mman721 M3 7 07-12-2006 04:03 PM
Beeping Noise 94bmw325i Geek Chat 7 06-26-2006 09:22 AM
vanos noise cabrit E36 3 02-17-2006 01:25 PM
Vanos Noise LHerbert E36 20 08-25-2005 11:26 PM
loose rattle noise in back Blumfepo E12, E28, E34, E39, E60 2 07-18-2005 08:05 PM
