Old 06-17-2006, 12:46 PM   #1
kenric
Fan problems
Hey guys. Started having a frustrating problem this morning when I went out. When I turn the car off, the fan inside the car won't shut off. I've tried playing around with turning off the fan with the car on and I can't even do that. Engine temp reads dead center.
All the local shops that I trust are closed on Saturdays. Any ideas on if this is going to shut off on it's own (without killing the battery?) Also any thoughts on pulling the fuse if it doesn't shut off?
I've got a solar charger plugged into it now but that'll only delay the inevitable if the fan doesn't shut off.
BTW, it's a 2000 232i.
Old 06-17-2006, 02:00 PM   #2
Rate My Car: 84 / 337
Is the A/C switched off? In my car, the fan to 0 will not work if the A/C is on to keep it from freezing. In my mom's car fan to 0 turns the A/C off instead.
Old 06-17-2006, 03:56 PM   #3
kenric
I was able to turn the A/C off but that didn't help at all. In the end I pulled the fuse, put it back in and the fan stopped acting up. I'm just worried this is some electrical gremlin.
Old 06-17-2006, 09:23 PM   #4
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
More then likely its your blower resistor. Its right infront of your blower fan under the dash. Accessable from the passanger foor well. They go for around 30$ and really dont take that long to install. They go bad all the time in E39's. Ive only replaced 2 in E46's.
Old 06-18-2006, 08:51 AM   #5
kenric
Thanks I'll replace that and hopefully it'll solve the problem
Fan Delete Kit ? Risky MOd? defkon99 E36 51 02-18-2010 07:34 PM
Heater Fan Switch Not Working? c1apton BMW General Discussion 4 12-14-2005 01:49 PM
Opinions of Fan Delete ///95M3 E36 10 06-02-2005 08:47 PM
fan whine Spieluhr E36 5 05-17-2005 09:30 PM
