Old 05-11-2006, 03:15 PM   #1
saltcoats
Your Ride: 1999 323ise
Question slight knocking sound to rear wheel area
hi ive got a slight knocking sound around left rear wheel area usually when turning right and going slow after advice I changed my shocker but to no avail I'm in the uk so its right hand drive when changing shocker I had a look round everything thing seemed ok anyone any ideas
Old 05-11-2006, 05:09 PM   #2
doughboyea
doughboyea's Avatar
Your Ride: 2007 Acura TSX
Welcome!
I'm sorry I really have no idea, but are you sure its comming from the wheel well? Have you checked the other things in that area. Within the well, how's the wheel? Is it worn? Is the rim bent? Is the paneling inside the well loose? What does the knocking sound sound like exactly? Like metal on metal? Or is it more of a thump thump sound? How are your brakes? Rotors... pads... caliper...? do you have sport suspension? After market?
I'm no mechanic, I'm just trying to open this up incase anyone else knows of your situation.
Just incase you have something similar to what I've experienced... I have Dinan's Stage 1 suspension kit installed. When I'm going slow, making a turn, I hear a sound from my suspension that sounds like something is rubbing, though it's not a knocking sound.... Dealer told me that it's natural from the Dinan suspension components.
Dough
Current Ride
2007 Acura TSX w/Navi
Past rides:
1989 Mercedes 190E 2.6
1980 Mercedes 240D
Old 05-11-2006, 05:36 PM   #3
Rate My Car: 137 / 337
Check & make sure all your exhaust hangars are in place. If one is loose or missing the exhaust might rattle against a heat sheild or rub on driveshaft. Also if you jack up rear end of car, check the half shafts for play (could be rear bearing, etc)
Old 05-11-2006, 07:18 PM   #4
Rate My Car: 183 / 337
rear shock mounts as a suggestion ?
Old 05-12-2006, 05:21 AM   #5
saltcoats
thanks for the replys to my query everything around the wheel seems fine panels springs wheel itself all seem solid I've checked exaust and that also seems solid no play in it at all the sound is like a dull clicking as I turn right theres no sound if I go over humps or pot holes except the usual noise from suspension that seems fine do you think I should just go to dealer there very expensive in the uk but what the hell the cars worth it eh :-)
Old 05-12-2006, 05:43 AM   #6
I'm guessing it's a rear CV joint. (they're covered by the rubber boots) They are a type of U-joint that spin & flex and when the load shifts on & off them (when worn) they'll make clicking noises. I'd have a qualified shop or the dealership take a look at them. They are not really cheap or easy to replace but don't let it go too long, if they break they'll coat you ALOT more $$$ and headaches
Old 05-12-2006, 05:49 AM   #7
saltcoats
thanks mate will do
Old 05-25-2006, 02:43 PM   #8
saltcoats
sorted it was cv joint took it to local garage cheers for all the help
E36 Rear trailing arm bushing replacement Dudesky BMW OEM Parts Department DIY's & FAQ's 19 06-01-2011 11:02 AM
DIY: Install Rear Shades on your E36/E46/E34 BMW! delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-26-2007 10:41 AM
CLICKING SOUND fROM rear end ? WTF? defkon99 E36 34 10-18-2006 01:00 PM
DIY: Add M3 steel guage rings to E36+ Remove Steering Wheel & Cluster. (pics) delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-09-2005 12:05 PM
E46 Audio Information - This is a god-send. EcianIce Car Audio and Electronics 4 04-21-2005 02:22 PM
